Why does My BLitz BOV do this?
Old Jun 29, 2004 | 08:26 PM
KeithGSR's Avatar
Default Why does My BLitz BOV do this?
When I drive it and get on the gas, as soon as the turbo starts to spool it seems like my bov trys to release. It doesnt seem like it can hold the pressure? What should I try?
Old Jun 29, 2004 | 08:28 PM
Quaalude's Avatar
Default Re: Why does My BLitz BOV do this? (KeithGSR)
Is there an adjustment screw for stiffness?
Old Jun 29, 2004 | 08:31 PM
KeithGSR's Avatar
Default Re: Why does My BLitz BOV do this? (Quaalude)
yeah. its a nut with a bolt that has a allen socket tip....
Old Jun 29, 2004 | 09:18 PM
95excoupe's Avatar
ummm make it tighter, I guess you don't really get the concept behind a BOV it lets the pressure out of your pipes so that when you close the throttle it doesnt stop the turbo, whats happening is its too loose and air is escaping before the throttle is closed. Loosen that nut and tighten that Allen head up a couple turns then tighten that nut back up, it should be clean sounding and there shouldn't be any fluttering sounds.
Old Jul 3, 2004 | 09:30 AM
KeithGSR's Avatar
Default Re: Why does My BLitz BOV do this? (95excoupe)
WOuld this help with my turbo from spiking high psi too quick... It seems my pis gauge jumps to like 10+ psi quick with out transferring any of the power to the car....I never boosted past 5psi in this car. Im guessing I am now because I rebuilt my turbo front end and I loosened the actuator rod on the wastegate. It was sort of stuck but it moves good now that I got some wd-40 in there....?????
Old Jul 3, 2004 | 10:38 AM
95excoupe's Avatar
Sounds like a boost leak check your pipes.
turboteg95
Sep 2, 2006 09:50 PM
Beau Gotti
Sep 20, 2005 02:21 PM
1 Cam Wonder
Dec 14, 2004 03:52 PM
DownBoyDown
Feb 2, 2004 09:19 AM
igo4bmx
Jun 4, 2003 01:41 PM
