O-ringing
Old Nov 16, 2003 | 07:39 AM
nuro's Avatar
Default O-ringing
Is it a good idea to o-ring a motor built for boost? Can someone explain why, or possibly why its a bad idea/unecessary (if so)?
Old Nov 16, 2003 | 08:48 AM
SpoolnG2's Avatar
Default Re: O-ringing (nuro)
yeah, its a good idea. you use a stock honda head gasket, and the copper o-rings allow for it to make a better seal.
Old Nov 16, 2003 | 09:34 AM
nuro's Avatar
Default Re: O-ringing (SpoolnG2)
and this option is better than just gettin an aftermarket head gasket?
Old Nov 16, 2003 | 09:37 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Yes, it is... I went through an entire season on 26psi on 1 stock head gasket, with copper spray and copper o-rings . I am not a fan of aftermarket head gaskets
Old Nov 16, 2003 | 12:19 PM
nuro's Avatar
Default Re: O-ringing (SIXTYdashONE)
this will be for a 15psi application tho
Old Nov 16, 2003 | 12:20 PM
HT's Biggest Loser
Ok?! so if mine can handle 26, you think it will handle 15?
Old Nov 16, 2003 | 12:28 PM
SpoolnG2's Avatar
i agree, theres nothin like an OEM headgasket. get the copper o-rings and run a OEM gasket...if i'm correct, dont a lot of pros do that to?
Old Nov 16, 2003 | 03:30 PM
nuro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTYdashONE &raquo;</TD></TR><TR><TD CLASS="quote">Ok?! so if mine can handle 26, you think it will handle 15?</TD></TR></TABLE>
thats not what i meant. what i meant was, at my boost level, do i even need to worry about it, or is it just pointless?
Old Nov 16, 2003 | 03:58 PM
earl's Avatar
Most sleeving companies will give you the option of O-rings or stepped deck. Both methods work equally as well. It is more labor intensive and takes more skills to do O-rings than a stepped deck.
You do not want to use o-rings with a stock sleeve block, however.
Ask your sleeving company if they offer this option at no extra charge.
arielmalespin
Mar 13, 2007 02:32 AM
jarven093
Mar 3, 2007 10:39 PM
slows2k
Sep 26, 2006 10:38 PM
honda-freak
Apr 14, 2006 12:24 PM
trustsohc
Jul 23, 2003 06:50 AM
