why????
Old Nov 28, 2007 | 02:15 PM
  #26
turboteg90's Avatar
pm for noodz
Default Re: (Schister66)
like 5 min before this happen everything was running right,i just happen to turn off the car now the battery is dead that fast
Old Nov 28, 2007 | 02:23 PM
  #27
turboteg90's Avatar
pm for noodz
Default Re: (turboteg90)
now the car just cranks then cliks
Old Nov 28, 2007 | 02:30 PM
  #28
TDogg Teg's Avatar
Go get some cables and jumpstart it with another car. Soundz like a dead batt to me.
Old Nov 28, 2007 | 03:15 PM
  #29
sohczcturbo's Avatar
Default Re: (TDogg Teg)
that or a bad ground maybe.
Old Nov 28, 2007 | 03:44 PM
  #30
mattssi's Avatar
classic dead battery. Also sounds like dude is running his car on a basemap. That is a safe way to roll on your way to get tuned correctly, but over time, running a basemap can cause damage to the engine and fuel system.
Old Nov 30, 2007 | 07:08 PM
  #31
turboteg90's Avatar
pm for noodz
Default Re: (mattssi)
http://www.youtube.com/watch?v=iZSDUkj_fA8
Old Nov 30, 2007 | 09:02 PM
  #32
batboyvaj's Avatar
from the vid, i think your alt. is shot
Old Nov 30, 2007 | 10:41 PM
  #33
TDogg Teg's Avatar
Default Re: (batboyvaj)
I was gonna post the same thing. Go to sears and get a get a volt meter (only 15 to 20 bucks for the simple digital ones) and check your voltage at idle and at revs. You should be 13.8 to 14.3. If you not, your alt is goin bad.
Old Nov 30, 2007 | 10:50 PM
  #34
mike93eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteg90 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.youtube.com/watch?v=iZSDUkj_fA8</TD></TR></TABLE>
usually if you disconnect the battery and the car dies then your alternator is shot.. you can also place something metal up against the alternator while the car is running and it should be magnetic if its working right. you can also check the battery volate witht eh car running. should be high 13 to low 14 volts.
Old Nov 30, 2007 | 11:03 PM
  #35
187Chor's Avatar
get it tuned before you blow ur motor
and what size is ur exhaust piping?
Old Dec 1, 2007 | 05:59 AM
  #36
turboteg90's Avatar
pm for noodz
Default Re: (187Chor)
3 inch piping
Old Dec 1, 2007 | 07:53 AM
  #37
Clayton's Avatar
H-T Administrator
25 Year Member
I realllly hate to say this, but why not take your car to an expert? T1 is in your neck of the woods, and Tony is a decent guy that'll likely help you out. Not for free mind you, but he'll get you on the road again
Old Dec 1, 2007 | 08:28 AM
  #38
turboteg90's Avatar
pm for noodz
Default Re: (Clayton)
yea i was thinking of doing that but first i want to get the car running right so it wont blow on the dyno
Old Dec 1, 2007 | 08:54 AM
  #39
187Chor's Avatar
well the reason its not running right is BECAUSE its not tuned!
at this rate u wont blow it on the dyno it will blow on the freeway!
Old Dec 1, 2007 | 01:44 PM
  #40
TDogg Teg's Avatar
Dude, your alt is bad, Im telling you. Go buy an alt, get it running again and call Tony. He'll steer you in the right direction and get your ecu tune right for you.
Old Dec 1, 2007 | 02:37 PM
  #41
JLman86's Avatar
Default Re: (da_dude)
your running rich, my built ls did that to. was running 680cc injectors on 7psi with just a chipped base map and it did the same thing. but from like 6000rpm to 7300. my car was a fat gas wasten pig, but it was quick. was, lol
Old Dec 1, 2007 | 06:23 PM
  #42
turboteg90's Avatar
pm for noodz
Default Re: (JLman86)
how does it run after tune and was it the stock ecu you tune or you got a different one??
Old Dec 1, 2007 | 07:29 PM
  #43
HiProfile's Avatar
2 years of daily driving w/o running dextron cleaner every couple tanks can allow your injectors to clog up a bit, as well as leave enough deposites on your valves to seriously pact AFR's. Chances are your engine is dirty, and isnt' getting enough air inside as it did when it was tuned.
The other thing, if your alt is dead, chances are you could be running lean on top. Your car pulls more energy near redline, meaning less voltage to the injectors. Its well known that if your tuner didn't set up the voltage tables for your injectors, it will run lean when the voltage drops too much. Lean = detonation = lost power. Also low battery = more likely to misfire = lots of lost power.
First change your alternator (after getting yours checked). hen change to NEW NGK copper plugs, heatrange 7, gapped to .028-.030" or so. THEN run a bottle of dextron fuel cleaner through your car, and see how it runs. You should also check the rotor/cap/plugs. They are supposed to be replaced once a year, and definately no longer than once every other year. FYI don't use cheap ****, it will be asking for more problems.
Old Dec 2, 2007 | 04:22 AM
  #44
TDogg Teg's Avatar
Default Re: (HiProfile)
^^^^^good info...Take heed turboteg, and no shortcuts.
Old Dec 3, 2007 | 03:43 PM
  #45
turboteg90's Avatar
pm for noodz
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">
then change to NEW NGK copper plugs, heatrange 7, gapped to .028-.030" or so.</TD></TR></TABLE>
which ones are they,thres alot of plugs
http://ngksparkplugs.com/
Old Dec 8, 2007 | 11:59 AM
  #46
turboteg90's Avatar
pm for noodz
hey you guys the car fix it self,maybe it was sputtering because it only had less than 1/4 of gas i fill it up and now its freaking fast
http://youtube.com/watch?v=gCRHnwmtUiI
Old Dec 12, 2007 | 06:18 AM
  #47
TDautowerkes's Avatar
Default Re: why???? (turboteg90)
restrictive exhaust.....................
Old Dec 12, 2007 | 06:31 AM
  #48
93CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteg90 &raquo;</TD></TR><TR><TD CLASS="quote">hey you guys the car fix it self,maybe it was sputtering because it only had less than 1/4 of gas i fill it up and now its freaking fast
http://youtube.com/watch?v=gCRHnwmtUiI</TD></TR></TABLE>
Lol.. problem solved
khmboostedeh2
Jun 10, 2004 10:15 PM
viet4gvtec
Sep 4, 2003 07:29 PM
civicdragger818
Jun 24, 2003 08:09 PM
phantomCIVIC[99]
Apr 16, 2003 12:09 PM
gliaw
Mar 13, 2003 11:29 AM
