who is using the greddy profec b spec II
I am having trouble with getting my greddy to control boost and think I have it hooked up wrong. Would someone be so kind as to tell me where each and every vacuum line is hooked up. Where the lines from the wastegate to the solenoid go and which side. and then where you tapped in for the controller box inside the car.
Thanks!!!
Thanks!!!
Re: who is using the greddy profec b spec II (syclone50)
http://www.greddy.com/img/PHP/products/pdf/689.pdf
I haven't installed mine yet, but hopefully this helps you.
Re: (syclone50)
what settings are you using? and again, are you positive you have it installed correctly? is the car just over boosting in general or is it creeping or spiking at all?
dcmodnight
08-02-2011 09:44 PM
