no boost?
Old May 27, 2008 | 07:19 PM
4dek's Avatar
Default no boost?
cant hear my turbo spool and my blowoff valve doesnt even open.what could be posibly wrong? im using 2inch charge pipes could that be it? pls help guys
Old May 27, 2008 | 07:26 PM
turbodano's Avatar
Default Re: no boost? (4dek)
pics please. How long has your car been turbocharged?
Old May 27, 2008 | 08:59 PM
4dek's Avatar
Default Re: no boost? (turbodano)
its been a day.
Old May 28, 2008 | 06:16 AM
chimmike's Avatar
we need a whole lot more info. setup, manifold, turbo, blow off valve, how your vac lines are run, what wastegate, etc. etc.
check for boost leaks?
Old May 28, 2008 | 08:14 PM
4dek's Avatar
Default Re: no boost? (chimmike)
just discovered a leak on the exhaust, i didnt use all 5 bolts for the downpipe flange that is connected to the turbo i only used 4 because 1 of the bolt wont go in because of the weld on the downpipe and flange to the turbo. i can hear exhaust coming out of the bolt hole, would this little leak cause the no boost problem considering its just a small hole? would this affect the turbine from spooling even its on the flange. i need help guys pls
Old May 28, 2008 | 08:34 PM
95delsolz6's Avatar
Check your charge pipe clamps. Especially if you're using the wormgear style.
Old May 28, 2008 | 09:35 PM
4dek's Avatar
Default Re: no boost? (95delsolz6)
checked intake but no leaks
Lao17
Apr 30, 2011 08:59 PM
turbohatch96y7
Jun 18, 2009 06:51 AM
importdude2000
Jun 20, 2006 11:30 AM
90AcuraIntegra04
Feb 4, 2006 04:35 PM
GOLDBERG
Apr 15, 2003 09:32 PM
