white smoke while boosting????
Old Sep 9, 2003 | 09:08 PM
B_1_8_hatch's Avatar
Default white smoke while boosting????
i had a hwy run this past weekend and when i got on it at full boost, there was white smoke coming out the muffler. when i drive normal, there was no white smoke, but when i boost, i would see white smoke in my rear view mirror.
recently...my gaskets under the valve cover were bad and a lot of oil got into the spark plugs. i changed the gaskets and the plugs and i was just wondering if it could be all the oil that got into the block burning up when i got on it?
i'm going to take the exhaust piping off the turbo sometime this week to see if there's oil in there. i hope there not though.
this guy told me he thinks i'm running too much fuel. at idle...my fuel pressure guage reads 58-59psi. i'm running 8psi on a b18b1 right now.
let me know what you guys think.
Old Sep 9, 2003 | 09:12 PM
Haberdasher's Avatar
Default Re: white smoke while boosting???? (93hb)
white smoke is water going through combustion. Check for a blown head gasket. It could be blown such that it only presents itself when under boost. Do water temperatures go up when under boost, or is the radiator overflow reservoir full/over full?
Old Sep 9, 2003 | 09:16 PM
temps are below normal.
no over flow or anything like that from the resevoir tank. its full, not over full.
could it have anything to do with my return line if its clogged or if something may be wrong with it?
Old Sep 9, 2003 | 09:27 PM
T-sohctec's Avatar
Is it alot of smoke, and does it come on right as you boost.
Maybe your oil seals are bad in the turbo?
Old Sep 9, 2003 | 09:36 PM
yeah...its kinda a lot of smoke. it doesn't happen right when i boost. when the boost hits 8psi, then smoke will come out.
i just talked to my friend, who was behind me , he said it was black smoke. to me it looked like white smoke in my rear view mirror though.
my fuel pressure guage is reading almost 60psi at idle. isn't that high? i thought it should be like 39-43psi at idle. i have a walbro intank fuel pump and a vortec fmu with the stock fpr. i think i need to get an adj fpr to turn the fuel pressure down.
i hope it was black smoke and not white smoke. would black smoke look like white smoke when looking from the rear view mirrow and there's like 10 cars behind me with their lights on????
Mikeedubb
Oct 14, 2011 03:57 AM
siblue_gzer
May 9, 2007 11:31 AM
CRX_Control
Nov 10, 2004 09:29 PM
Layziebtnh055
10
Apr 16, 2004 02:22 PM
Broken Gearbox
Aug 8, 2003 09:00 AM
