where to hide the n20?
Old Apr 22, 2004 | 04:58 PM
  #26
h22 civic's Avatar
Default Re: (GITWIDIT)
gut the foam out the seat and mount bottle in their
Old Apr 22, 2004 | 05:13 PM
  #27
SeanEF's Avatar
Default Re: (h22 civic)
Some guy that used to hit up the street races claiming he was ALL MOTA turned out to have a sneaky pete mounted in his frame under the passenger side..and had all the lines run up underneath his intake
Old Apr 22, 2004 | 05:18 PM
  #28
tegasaurus's Avatar
Default Re: (Sulli)
yeah, i bet that rust bucket truck is a real sleeper... what with the 10 gallon fuel cell and all
i have mine mounted in the back in the middle but there's so much **** back there you can't even see it... clothes, books, a backpack, grocery bags, etc.
just make your car looks liek a pice of crap and poeple wont even bother questioning if you have nitrous or not
Old Apr 22, 2004 | 05:32 PM
  #29
spoolinlude's Avatar
I live under a rock
Default Re: (tegasaurus)
i like the chevy manifolds, u can hide the direct port system in the space between the intake and the lifter valley......... i think u can actually buy this premade now........ friends uncle used to do setups like this all the time 10years ago
Old Apr 22, 2004 | 06:03 PM
  #30
kid-honda's Avatar
You should only hide for a clean look, not to lie like a bitch.
Old Apr 22, 2004 | 06:12 PM
  #31
david@didrace.com's Avatar
Default Re: (kid-honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda &raquo;</TD></TR><TR><TD CLASS="quote">You should only hide for a clean look, not to lie like a bitch.</TD></TR></TABLE> Lose your money to someone faster than you?
Old Apr 22, 2004 | 07:28 PM
  #32
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: where to hide the n02? (jkjb16a)
hey i was wondering the same i like how someone did the blue bottle but i was wondering can u run direct port nitrous on the bottom of the manifold if u have room?
Old Apr 22, 2004 | 08:01 PM
  #33
jdm_redneck's Avatar
Default Re: where to hide the n02? (CrxStreetRacer)
In my eg, i took the right rear plastic side panel off and made a custom piece that allowed the bottle fitment inside, it looked like factory, unless u really looked closely.
Old Apr 22, 2004 | 09:15 PM
  #34
Default Re: (spoolinlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinlude &raquo;</TD></TR><TR><TD CLASS="quote">i like the chevy manifolds, u can hide the direct port system in the space between the intake and the lifter valley......... i think u can actually buy this premade now........ friends uncle used to do setups like this all the time 10years ago</TD></TR></TABLE>
You can run all the lines straight through a hole in the bell housing too so that there are absolutely no exposed lines.
Old Apr 22, 2004 | 10:03 PM
  #35
XSIintegra's Avatar
Default Re: (10-94-55)
The times I went to the track in my '92 Teg and the nitrous was never found. The only think I did was hide the lines under the hood. Any braided SS lines where wrapped in plastic wire loom* wrap. worked great
Old Apr 23, 2004 | 01:29 PM
  #36
h22 civic's Avatar
foe sure that was a good old one for a few years and even if you know its their you still cant prove it cause im not going to let you take my intake off
Old Apr 25, 2004 | 09:12 PM
  #37
bottlefedb18c1's Avatar
Default Re: where to hide the n02? (00siBuilder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00siBuilder &raquo;</TD></TR><TR><TD CLASS="quote">
haha you dick.... people always thought i was running n02 because of guys like you. all motor=pride</TD></TR></TABLE>
hey you have to do what you have to do to make some extra money
Old May 11, 2004 | 03:23 PM
  #38
allmota1.8's Avatar
Default Re: where to hide the n02? (bottlefedb18c1)
bump 4 more info....!!!!!!
Old May 11, 2004 | 06:10 PM
  #39
red91sit's Avatar
How do you get your bottle out from under the dash to refill it?! I got mine in the trunk with a huge sub box with 3 12 in subs in it and it barely fit in my trunk (involved me hitting the box and yelling for a long time and finally it went in but i now the only way it's coming out is in many many pieces. Anyways i just open my backseat to get it at. So far no body noticed.
Old May 11, 2004 | 06:34 PM
  #40
ringgold's Avatar
Default Re: where to hide the n02? (red91sit)
I knew some guys back home that had some awsome ideas for hiding nitrous.
I have seen switches mounted in the seat belt clips, one of the horn switches on the steering wheel as a switch, cigarette lighter as a switch.
I have seen dry setups that didnt even use a fogger or anything of the sort didnt even use steel braided hoses from the solenoids to the initial injection point into the engine. They actually used this really small black nylon hosing that was big as the jet that you put into the fogger. So the hose was its own jet and that junk could never be found especially when it was ran with the factory engine wiring harnesses on cars.
Dry shots from my experience are the easiest to hide because you dont have to plumb any fuel lines in with the nitrous. They would just make the cars run richer and just spray the hell out of them with nitrous.
Old May 12, 2004 | 07:11 AM
  #41
Boostin95Teg's Avatar
Default Re: where to hide the n02? (ringgold)
i had a bazooka sub box (round box), i had my 10lb bottle hid in there with the steel braided line covered in wire look until it was hid under the carpet..solonids under dash...no one ever spotted it
Old May 12, 2004 | 07:39 AM
  #42
tegon-gsr's Avatar
behind your driver seat and then cover it with a black or what ever color your carpet is. that way you dont need no bottle opener just turn twist and hear that shhhhhhshhshhhhh. and go.
Old May 12, 2004 | 09:55 AM
  #43
CRX T-Si's Avatar
Default Re: where to hide the n02? (tegon-gsr)
You people crazy. If you got it why hide it.
When & if I put NOS in my rust bucket I will proudly display them just like that damn movie(The Fast & Furious). Little bit of rice but hell I will not pay so much money for something like that so I can hide it.
NOS to me it's just cool to have, I may not use it but just for the hell of it.
Look at it this way people, when a girl gets implants do you think she will cover it up??? Of cause not that bitch will use it to her advantage to get what she wants. After all she did pay lots of $$$ for those twins.
This is just my 0.02cents.
Old May 12, 2004 | 10:32 AM
  #44
RobbieG35's Avatar
12 Years Strong
Default Re: where to hide the n02? (CRX T-Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">You people crazy. If you got it why hide it.
This is just my 0.02cents.</TD></TR></TABLE>
Whatever you do NEVER mention that movie anywhere on Honda-Tech, not trying to be a dick, but it tends to attract negativity
Old May 12, 2004 | 05:18 PM
  #45
allmota1.8's Avatar
Default Re: where to hide the n02? (HybridHatch88)
the reason i ask where to hide it because if i hit a v8 to run in my area and the car is turbocharged or on the bottle they think the car runs low 11s. thanks to a crew with fast *** cars(trackmasters)so i go out to a race a v8 and they see my bottle they think every import is a trackmasters car. so thats why i asked where to hide the goods. big up to the trackmasters crew fast *** cars ..
Old May 12, 2004 | 05:21 PM
  #46
allmota1.8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrxStreetRacer &raquo;</TD></TR><TR><TD CLASS="quote">hey i was wondering the same i like how someone did the blue bottle but i was wondering can u run direct port nitrous on the bottom of the manifold if u have room?</TD></TR></TABLE>???? good question can you?????????
Old May 12, 2004 | 06:04 PM
  #47
Terrabomb's Avatar
NEGATIVITY! NEGATIVITY! NEGATIVITY! NEGATIVITY! NEGATIVITY! NEGATIVITY! NEGATIVITY! NEGATIVITY! NEGATIVITY! NEGATIVITY! NEGATIVITY! NEGATIVITY!
Also I would like to know if you can mount the direct port nozzles on the bottom of the intake manifold It would really hide it down there.
Also. Someone give me a link to where you can buy a Sneaky Pete Setup please.
Old May 12, 2004 | 06:41 PM
  #48
4 CYLINDERS OF JUSTICE's Avatar
Default Re: where to hide the n02? (Terrabomb)
what you should do is take regular N2O bottles, and glue the labels from the faux-NOS subwoofer bottles on them. If people ask about the plumbing, just tell them its speaker wire. FUNNY.
Old May 15, 2004 | 09:57 PM
  #49
PMP_C_TEG's Avatar
mine was just relocated to my spare tire well from the left side of my hatch.
RallyRedGT-V6
Apr 22, 2004 02:06 PM
EF-Pimp
Audio / Security / Video
Nov 27, 2003 01:32 PM
ninja8oi
Sep 24, 2003 06:29 AM
JLange
Aug 26, 2003 09:20 AM
TypeR1558
13
Oct 6, 2002 02:06 PM
