where to hide the n20?
Old Apr 20, 2004 | 07:34 PM
allmota1.8's Avatar
Default where to hide the n02?
i would like to see where some of you guys have hide your n02 set or any suggestion? let me know. thanks. B16 head in a ef body
Old Apr 20, 2004 | 07:41 PM
Mr Boston's Avatar
Default Re: where to hide the n02? (jkjb16a)
Someone on Honda-Tech has his bottle hidden in a duffle bag
Old Apr 20, 2004 | 08:00 PM
m R g S r's Avatar
Default Re: where to hide the n02? (Clicky Pow)
In my trunk mounted between the sub boxes. Ohh wait, it's not hidden, it's kinda on display.
Do you mean the solenoids and the jet going into the intake?
Old Apr 20, 2004 | 08:44 PM
bradford's Avatar
Default Re: where to hide the n02? (m R g S r)
Make a dummy speaker box big enough to fit everything in it, thats what I would do.
Old Apr 20, 2004 | 09:42 PM
dfoxengr's Avatar
Default Re: where to hide the n02? (bradford)
sneaky peet's under the seats...
Old Apr 20, 2004 | 10:30 PM
Kataku2K3's Avatar
Default Re: where to hide the n02? (hybridvteceg)
Not that it really matters but nitrous is N2O, dinitrogen oxide. Anywho this a setup I did awhile back... Nothing special but it was pretty hidden.
Old Apr 20, 2004 | 10:43 PM
jarel's Avatar
Default Re: where to hide the n02? (Kataku2K3)
never seen it on the firewall. Just have to stick back a cut-up dash and you'll neveerrrr know. hahaha.
sneaky petes are good to put anywhere.
Old Apr 20, 2004 | 10:51 PM
Kataku2K3's Avatar
Default Re: where to hide the n02? (jarelee)
I didn't have to cut the dash at all, just remove the heater core, bypass or A/C conderser box, and the blower. No heat sucks but oh well.
Old Apr 20, 2004 | 11:09 PM
AzCivic1.6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">I didn't have to cut the dash at all, just remove the heater core, bypass or A/C conderser box, and the blower. No heat sucks but oh well.</TD></TR></TABLE>
very nice
Old Apr 21, 2004 | 04:41 AM
the-anti-crack's Avatar
nice.
not having a heater in oregon must suck.
i lived there for 23 years......now i see sun and blue skys every day
Old Apr 21, 2004 | 02:39 PM
allmota1.8's Avatar
solenoids and the jet going into the intake? i would also like to see picks of where i can hide the jets and solenoids. sorry bout the type0 i was typing to fast
Old Apr 21, 2004 | 02:46 PM
DaX's Avatar
DaX
Loved
Community Favorite
I saw someone mount the solenoids on the steering rack...very hard to see. It was direct port and all the nozzles were on the under side of the manifold.
Old Apr 21, 2004 | 02:47 PM
allmota1.8's Avatar
thats a nice spot to hide the bottle
Old Apr 21, 2004 | 03:43 PM
david@didrace.com's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">Not that it really matters but nitrous is N2O, dinitrogen oxide. Anywho this a setup I did awhile back... Nothing special but it was pretty hidden.
Did you modify the pickup in any way? The bottle is supposed to be angled so the pickup is submerged at all times.
Old Apr 21, 2004 | 03:58 PM
bottlefedb18c1's Avatar
Default Re: where to hide the n02? (10-94-55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10-94-55 &raquo;</TD></TR><TR><TD CLASS="quote">
Did you modify the pickup in any way? The bottle is supposed to be angled so the pickup is submerged at all times.</TD></TR></TABLE>
agreed
unless you took the valve out and bent the tubbing 180 deg so it is not out of the liquid
i will see if i can get some pics up but a breif on it
i have the bottle in the spare tire hole
and the 4 silinoids inside the car with the purg all plummed though the fire wall going into the intake tube on the bottom and i am telling you this it is hard to see
i am willingly will pop my hood to show anyone that i am allmotor
i will get some pics up for you guys
Old Apr 22, 2004 | 12:12 AM
5STAR3's Avatar
Default Re: where to hide the n02? (bottlefedb18c1)
i like the duffel bag
Old Apr 22, 2004 | 06:39 AM
Griffin@Camtech's Avatar
mine in my EK was behind the passanger seat and I kept a coat over it. it worked
Old Apr 22, 2004 | 06:45 AM
Happyman's Avatar
Default Re: where to hide the n02? (Stickdeath)
The best place I've seen that someone hid the bottle was they took an old duffle bag cut a whole in the bottom and put it over the bottle and then put clothes in the bag as well to cover the bottle if someone ever opened the bag...pretty good idea and it also helps keep the bottle warm.
Something like this:
Old Apr 22, 2004 | 06:46 AM
00siBuilder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bottlefedb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">
agreed
i will get some pics up for you guys</TD></TR></TABLE>
haha you dick.... people always thought i was running n02 because of guys like you. all motor=pride
Old Apr 22, 2004 | 07:45 AM
Kataku2K3's Avatar
Default Re: where to hide the n02? (00siBuilder)
Yea, this particular bottle was opened up and has a modified sump. I plummed the feed line through the chassis on the passenger side of the car forward which then runs up into bracket holding the nozzle in the stock airbox. Solenoids and relays as you can see are all under the dash.
Old Apr 22, 2004 | 12:35 PM
allmota1.8's Avatar
this is going good any more ideas????? i would like to see some of the pics with the direct port system being on the under side of the manifold
Old Apr 22, 2004 | 12:55 PM
st00pid's Avatar
When I had my 98 DX I built a bracket for the 10lb bottle in the front bumper. I had the dry shot ran to the cold air intake. I ran the car rich all the time and sprayed a 75 shot on the stock SOHC. It was good for mid to low 13s
The people that knew about it thought I was insane for having a 1300psi bottle in the front of my car but i figured if I got into a wreck I was screwed anyway. Besides theres a nice engine block to protect me.
Old Apr 22, 2004 | 01:16 PM
allmota1.8's Avatar
Default Re: where to hide the n02? (st00pid)
thats nuts in the bumper?
Old Apr 22, 2004 | 02:10 PM
Smokinsax's Avatar
The Boot
That bag is hilarious!
There was a time that people had heard that I was running nitrous. My hatch was completely gutted and all I did was throw a towel over it. "If he's runnin' NAAWZ I dont see it anywhere?!?!" HAHA!
Old Apr 22, 2004 | 02:26 PM
gitwidit's Avatar
Ever seen someone cut the bottom out of a big tackle box and use it to hide a bottle?
