Where does my oil go?!
I have a built b16 motor with the following.
9.5:1 je pistons
eagle rods
polished crank, cams, valves, rods
3 angle valve job
and compression numbers range from 190-200.
i seem to burn 1 quart of oil a month. And I was wanting to put boost through the motor but i want to get the oil problem figured out first. no smoke out the valve cover breather or exhast. the motor sounds like a diesel a little bit also but everyone has said it was ok, for example a few shops around here, Kansas, TX.
so if anyone has a clue that would be awesome.
P.S. the motor was broke in properlly with non-synthetic oil and has only ran synthetic oil since brake in.
thanks,
the slow one
9.5:1 je pistons
eagle rods
3 angle valve job
thanks,
the slow one
Thanks for the reply but know i have another question. Where do i go to get a leak down test done? thanks for the info.
and im out,
the slow kid
and im out,
the slow kid
Fact: high performance motors sip a bit of oil.
rather than a quart a month, how many miles per quart? that would give us a better understanding of whats going on. May be valve seals, may be your driving habbits, may be a combanation of both. And yes built internals make noise, my LS sounds like a diesel allso. You can performe a leakdown test yourself by going and buying a leak down tester.
Rob
Rob
Thanks for the help rjardy! I would say i drive about 1000-2000 a month depending one the situations. The motor now has 15,000 on it runs great just sips some oil so i was just wondering if i should go for the boost or not. I will be doing a leak down test and see what exactly is going on with my motor.
thanks again,
Slow kid
thanks again,
Slow kid
TeamCracka
Feb 23, 2004 12:28 PM
