Compression test fine, still burning oil..
Old Mar 27, 2005 | 09:31 AM
LSVTEC 91 Civic's Avatar
Banned
Default Compression test fine, still burning oil..
Okay, My compression is 270psi (+/- 3psi) across the board, my valve seals are new. I can only see smoke puff out when I let off after a good VTEC pull.
Ideas?
Old Mar 27, 2005 | 01:18 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: Compression test fine, still burning oil.. (LSVTEC 91 Civic)
specs on motor? could be a bad pvc valve, or you may need a better crankcase breather setup.
Old Mar 27, 2005 | 01:47 PM
asubennett's Avatar
Default Re: Compression test fine, still burning oil.. (PURPLETERROR)
Oil ring has nothing to do with compresion. . Your compression test will not show worn oil rings.
For the sake of simplicity you should check your PCV valve as suggested earlier.
Old Mar 27, 2005 | 02:45 PM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR &raquo;</TD></TR><TR><TD CLASS="quote">specs on motor? could be a bad pvc valve, or you may need a better crankcase breather setup.</TD></TR></TABLE>
Can you point me in the right direction? Thanks!
Running a B18A bottom, LS Crank & Rods, CTR pistons, B16A2 head.
Old Mar 27, 2005 | 03:12 PM
asubennett's Avatar
Really, the only way to tell is check you oil level periodically. If it is your oil rings I will bet that you will be adding oil with regularity.
Old Mar 27, 2005 | 04:47 PM
vinasity's Avatar
how much oil is burning?
Old Mar 27, 2005 | 04:56 PM
Banned
Default Re: Compression test fine, still burning oil.. (asubennett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asubennett &raquo;</TD></TR><TR><TD CLASS="quote">Really, the only way to tell is check you oil level periodically. If it is your oil rings I will bet that you will be adding oil with regularity. </TD></TR></TABLE>
The only oil I lose is from a leak... Cam seal/VTEC solenoid doesn't leak, and I just put in a new oil pan gasket with hondabond all around, and torqued to proper spec... STILL losing a lot of oil, its collecting on the bottom of the oil pan and leaking from there.
The only time I seem to burn oil, is after I let off after an 8k pull, and i'll see smoke coming out of the pipe for a few seconds afterwards.
Old Mar 27, 2005 | 05:06 PM
asubennett's Avatar
That sounds more PCV valve related then. Your generating a lot of crank crase pressure and if the PCV valve is clogged or not operating the presure escape via piston blow by and burns off in the combustion process, hence the white smoke under heavy load only.
Old Mar 27, 2005 | 05:11 PM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asubennett &raquo;</TD></TR><TR><TD CLASS="quote">That sounds more PCV valve related then. Your generating a lot of crank crase pressure and if the PCV valve is clogged or not operating the presure escape via piston blow by and burns off in the combustion process, hence the white smoke under heavy load only. </TD></TR></TABLE>
Cool, I'll check that out. Would a bad PCV cause an oil leak? I'm pissed! Still leaking a good amount of oil after I replaced all my seals.
Old Mar 27, 2005 | 06:01 PM
asubennett's Avatar
It wouldn't help it but I don't think by itself cause it. The more crank case pressure you have the more oil wants to be forced out somewhere. Path of least resistance. :-)
Old Mar 27, 2005 | 06:02 PM
asubennett's Avatar
For the oil leak did you check your oil presure sensor tee fitting. I had a leak there recently. Or the main oil feed line to your head from the LSVTEC mod.
Old Mar 27, 2005 | 06:07 PM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asubennett &raquo;</TD></TR><TR><TD CLASS="quote">For the oil leak did you check your oil presure sensor tee fitting. I had a leak there recently. Or the main oil feed line to your head from the LSVTEC mod. </TD></TR></TABLE>
Yep everything is good... Everything was cleaned and dry after all my seals were replaced, now oil is collecting at the bottom of my transmission and oil pan just like it was before.. what a mess.
Old Mar 27, 2005 | 06:16 PM
Dragline's Avatar
Do a leak down test .
Old Mar 28, 2005 | 05:59 AM
Banned
Default Re: Compression test fine, still burning oil.. (dragline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragline &raquo;</TD></TR><TR><TD CLASS="quote">Do a leak down test .</TD></TR></TABLE>
I plan on it.
My main concern right now is the oil mess, whatever it is, its coming from somewhere, and collecting at the bottom of the oil pan/transmission. Hopefully this is just the breather box/PCV valve. Who knows, I'll replace it and see what happens.
How do I improve my crankcase breather setup?
Old Mar 28, 2005 | 08:27 AM
asubennett's Avatar
Weld a couple AN fittings on the front of you valve cover above the baffling that is on the inside of the valve cover. Run two lines from the AN fittings to a catch can. Crank case pressure=gone.
jcskyhigh
Jul 25, 2007 01:24 PM
Renegade
Aug 31, 2004 10:25 AM
lakerschamp2000
Jan 26, 2004 05:53 PM
Excelerate
Sep 21, 2003 09:26 PM
Accel Junky
Apr 28, 2003 02:18 PM
