Where to buy Missing LINK???
Old Sep 29, 2003 | 12:42 AM
BoOsTiN Dc2's Avatar
Default Where to buy Missing LINK???
Can anyone tell me or link me to websites where i can buy a missing link for my lsvtec turbo for my 95 integra? Post it here and let me see what my options are, thanks
Old Sep 29, 2003 | 12:43 AM
Full-Race Henry's Avatar
Default Re: Where to buy Missing LINK??? (tRaCeBuStAbUsTeR)
you got pm
Old Sep 29, 2003 | 07:04 AM
racerxadam's Avatar
http://www.importparts.com/
Old Sep 29, 2003 | 07:20 AM
Blitzkrieg's Avatar
Default Re: Where to buy Missing LINK??? (racerxadam)
Why bother they are junk. Look into Jackson racing's MAP sensor clamp or better yet there is the Split Signal clamp for the maps sensor. I had countless issues relying on a mechanical check valve to bleed off boost going to the MAP sensor just so that it would not see boost. Do it electronicly. All you have to do is clamp off the MAP sensor voltage at the voltage that is equivelent to 0 boost and no vacuume. To find this value out just turn the key to the on postion then put a volt meter on the MAP sensor signal wire. With the engine off you are at atmophere pressure (0boost) . Just set the split signal peice to this voltage. You ECU will never see a voltage higher than this setting therefore it will not freak out. You never have to clean this unlike the check valve that gets dirty and sticks. http://www.spitsec.com
Old Sep 29, 2003 | 07:33 AM
SpoolnG2's Avatar
Default Re: Where to buy Missing LINK??? (Blitzkrieg)
or they also sell them on http://www.inlinefour.com
nicktagz
Sep 8, 2006 11:01 AM
redlseg
Apr 26, 2005 07:20 AM
intoracing
Aug 21, 2004 03:02 PM
94greddycivic
Jun 29, 2004 10:51 AM
