when should a 57 trim spool on a b16a2?
Old Oct 10, 2006 | 07:51 AM
92redhatch's Avatar
Default when should a 57 trim spool on a b16a2?
i have a 81mm b16 with 9 to 1 compression and i have a drag style manifold with a 57 trim master power turbo with a 63 ar. im just wondering when should it start to spool and when should it hit full boost?
thanx
Old Oct 10, 2006 | 07:58 AM
RacerXI's Avatar
Default Re: when should a 57 trim spool on a b16a2? (92redhatch)
Need more info, but in general it'll get the positive pressure going around 3K. How much boost are you running? Most see 10psi around 4800-5200. That's dependent on manifold, exhaust, cams, blah, blah, headwork, dirty ******, etc.
Old Oct 10, 2006 | 08:00 AM
SlowB16si's Avatar
Default Re: when should a 57 trim spool on a b16a2? (RacerXI)
full boost around 4800 on my stock b16, same turbo size and manifold 7.25psi
Modified by SlowB16si at 11:09 AM 10/11/2006
Old Oct 10, 2006 | 08:12 AM
Soccerking3000's Avatar
Default Re: when should a 57 trim spool on a b16a2? (SlowB16si)
tell us you get full boost at 4800 does nothing for us, what psi was that at? On my d16 i made 20psi at 5600 (b16 and d16 have similar spool times)
Old Oct 10, 2006 | 12:20 PM
92redhatch's Avatar
im at 6 psi right now.
Old Oct 10, 2006 | 12:22 PM
92redhatch's Avatar
b16 cams. rev valvetrain. type r tranny. 2.5 inch exhaust and downpipe. 2.5 in intercooler piping. anything else?
Old Oct 10, 2006 | 12:36 PM
saturnracing2's Avatar
Old Oct 10, 2006 | 01:22 PM
cuin9sec
Guest
Posts: n/a
Default Re: (92redhatch)
I would have to say around 4000-4500rpms...reason why I say this is because I was running a t3/t67 h.o. last year on a stock GSR and it hit full boost at 6500rpms and that was a .82 a/r hotside also...that thing hit ******* hard man...lol. traction = NONE lolz!
Old Oct 10, 2006 | 04:55 PM
Jay_Sensing's Avatar
I used to have a setup similar to that and I was hitting 12lbs about 4500 or so but the car wouldn't really feel strong until it crossed over.
Old Oct 11, 2006 | 06:38 AM
92redhatch's Avatar
thanks for the info. anyone else?
Old Oct 11, 2006 | 07:09 AM
93CX's Avatar
Hmm.. I have a T3/T04e .57 trim and I make 8 pounds before 4k.. maybe I just havent driven it in a while
Old Oct 11, 2006 | 07:25 AM
Intercooler size, exhaust size, and intercooler piping as well as timing in the tune can all affect spool time man.
Old Oct 11, 2006 | 09:16 AM
ExVtec's Avatar
Mine hits 21lbs right around 5700...
3" exhaust and 2.5" i/c piping.
Ramhorn style mani however.
Old Oct 11, 2006 | 11:26 AM
TS4L's Avatar
Default Re: when should a 57 trim spool on a b16a2? (ExVtec)
Dang that seems really laggy for that turbo, how much power were you guys making with it. Good thing you guys can rev these honda motors so high. I couldn't live with that power band.
Old Oct 11, 2006 | 12:40 PM
92redhatch's Avatar
ya how much power should i expect to make with this setup at 20lbs on a safe tune.
Old Oct 11, 2006 | 12:57 PM
Well, looking at exvtec's sig, I would say around 450whp at 21 lbs lol.
In all honesty, it will matter more who tunes it and the rest of the setup as to what you will make.
On that note, I now run the large SC61 with an E cover and with the tune on the car now, I can spool it quicker than I could my turbonetics .57 trim. It's odd but hey, things happen.
Old Oct 11, 2006 | 01:10 PM
Default Re: when should a 57 trim spool on a b16a2? (TS4L)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TS4L &raquo;</TD></TR><TR><TD CLASS="quote">Dang that seems really laggy for that turbo, how much power were you guys making with it. Good thing you guys can rev these honda motors so high. I couldn't live with that power band. </TD></TR></TABLE>
thats not laggy at all, it seems about right for a 1.6L motor
Old Oct 11, 2006 | 04:40 PM
StckOnHvyChcks's Avatar
my estimate would be right around 4600
Old Oct 11, 2006 | 06:21 PM
See Are X's Avatar
Default Re: (StckOnHvyChcks)
5000 here
Old Oct 12, 2006 | 04:18 AM
92redhatch's Avatar
any horsepower numbers with this setup or a similar setup?
Old Oct 13, 2006 | 11:33 AM
TS4L's Avatar
For the power leverl I would expect out of this turbo that just seems like a laggy choice. I'm not saying anything bad about this setup just not my personal taste. I just like my power a little quicker and would have gone with a 2871 or 3071 for this power level.
Old Oct 16, 2006 | 06:11 PM
92redhatch's Avatar
eventually i plan on changing the turbo.
Old Oct 17, 2006 | 05:49 AM
ExVtec's Avatar
Default Re: (TS4L)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TS4L &raquo;</TD></TR><TR><TD CLASS="quote">For the power leverl I would expect out of this turbo that just seems like a laggy choice. I'm not saying anything bad about this setup just not my personal taste. I just like my power a little quicker and would have gone with a 2871 or 3071 for this power level. </TD></TR></TABLE>
You do w/what you have.
Gt series turbo's are not $500 bucks brand new...
I don't feel full boost @6k - 9k is a bad powerband? Why would I want boost coming on sooner when my gearing never drops past 6k??
honda_mike
Oct 29, 2008 10:46 AM
batboyvaj
May 3, 2007 09:38 AM
Samuels
Jun 30, 2006 03:48 PM
sprayin95hatch
Jul 22, 2005 03:44 PM
mrx
Feb 11, 2005 07:28 PM
