How do I boost higher?
Old Apr 23, 2003 | 05:59 AM
incognitoracerr's Avatar
Default How do I boost higher?
Ok here is the thing...at first I did not know how to fix the darn boost controller...so now I got it to work fine...i have the greddy sohc turbo kit for the civic. Now I turned the boost up on the boost controller but I am not getting any boost above 5psi...what am i doing wrong...I know the factory setting is set to 5.5 psi on this kit but I thought that with the boost controller I could bring it higher...so how do I raise the boost?
Old Apr 23, 2003 | 06:15 AM
MiraiZ's Avatar
Default Re: How do I boost higher? (incognitoracerr)
which boost con?
Old Apr 23, 2003 | 06:18 AM
Default Re: How do I boost higher? (MiraiZ)
profec b
Old Apr 23, 2003 | 06:21 AM
MiraiZ's Avatar
try turning up the balance *** to about 2 oclock( or higher)...select hi boost and turn the *** up until you get the desired boost level
Old Apr 23, 2003 | 06:43 AM
ok i will try that...would this kit go past 5psi though?..even though the turbo is pre-set for 5psi would the boost controller allow it to go higher?
Old Apr 23, 2003 | 06:45 AM
Ubermensch's Avatar
That's the point of a boost controller.
Old Apr 23, 2003 | 06:52 AM
Default Re: (Ubermensch)
Ok...i will try the balance and get back with you guys to see if it works
ATS*Mark
Feb 18, 2004 01:25 PM
