What's wrong with this picture?
Old Jun 23, 2002 | 08:33 PM
1's Avatar
Default What's wrong with this picture?
Any educated suggestions?
Does Wilwood, etc. make a master cylinder with a slimmer reservoir that would bolt right on to a G2 Geezer?
Old Jun 23, 2002 | 08:36 PM
JM Performance's Avatar
Default Re: What's wrong with this picture? (1)
can you use something like radiator hose to move the reservoir to where it will fit?
[Modified by 00SilverLS, 12:36 AM 6/24/2002]
Ri5e's Avatar
MmmMmmmm JG/Edelbrock.....
Old Jun 23, 2002 | 08:39 PM
1's Avatar
Default Re: What's wrong with this picture? (BG Boost)
I was thinking of some sort of sleeve that would raise the reservoir a couple of inches since there is clearance below the hood.
Old Jun 23, 2002 | 08:44 PM
DR. ON POINT's Avatar
Banned
damn that sucks, I got no clue on what u should do
Old Jun 23, 2002 | 09:29 PM
pornstarSR's Avatar
hmmm R&D is a good thing, but not just on race cars
bound to happen, that sucks
Old Jun 23, 2002 | 09:31 PM
1's Avatar
Default Re: What's wrong with this picture? (pornstarSR)
Yes, you would think that I could have lined it up on our other GSR and foreseen the clearance issue
Old Jun 23, 2002 | 09:40 PM
pornstarSR's Avatar
i dont think you should be blaming yourself unless you work for JGedlebrock,
they should have checked that one, but like i said sometimes these things happen...
i have seen relocated resovours(dont know how its spelled)...I.E. in the dash (touring cars)
but personally if you can avoid modifying the brake master cylinder i would defintaly avoid it, because what happens when you loose fluid or something,
WAIT WAIT WAIT, GET OUT OF THE WAY, NO BRAKES
Old Jun 23, 2002 | 09:46 PM
1's Avatar
Maybe this one from Wilwood would work (say that 3 times fast).
Old Jun 23, 2002 | 11:23 PM
lucas569's Avatar
this would be going backwords but WOULD work, switch to a civic brake booster, should give you more clearance cause its smaller.
Old Jun 24, 2002 | 12:02 AM
MackSpeed-616's Avatar
Default Re: What's wrong with this picture? (lucas569)
does the reservior fit w/o that plug in the way? if so either screw it in farther or have a plate welded over the end of the manifold opening
Old Jun 24, 2002 | 02:50 AM
Default Re: What's wrong with this picture? (BustaNutt-616)
just find a
_|
shaped peice of rad hose and relocate it, no?
Old Jun 24, 2002 | 05:05 AM
Finest's Avatar
Default Re: What's wrong with this picture? (00SilverLS)
Simple solution: Move it up. I used a 3" long piece of radiator hose, I believe it was a 1.5" opening. Clamp both sides and you should be ok.
Old Jun 24, 2002 | 05:24 AM
RGAZ's Avatar
New User
Oh yeah, that's good.
Try a 90-91 CRX Si reseviour. They are much smaller in diameter but have the level switch built in.
take a look at it, not sure the diamter is the same though.
Randy
Old Jun 24, 2002 | 08:00 AM
Bnjmn's Avatar
I don't know if the Wilwood would work- it looks like it is built for a horizontal (flat) mount where as the Honda MC attatchment flange is at an angle.
Ben
Old Jun 26, 2002 | 10:32 AM
supergreenNA1's Avatar
New User
i have notified the engineer at edelbrock that designed the victor x manifold. i'll let u guys know if he has any feedback for us.
Old Jun 26, 2002 | 10:39 AM
1's Avatar
Default Re: What's wrong with this picture? (supergreenSol)
I have already emailed them. They didn't have problems fitting this to a G2 GSR but it must have had the B17 in it. I have a B18C and the extra deck height is probably creating the problem.
I think RGAZ has the best solution and I have one on order. I would not attempt a ghetto fix like radiator hose on a brake system.
Baten619
Sep 1, 2010 07:13 AM
JDMGTI
17
Sep 30, 2009 07:52 AM
h22lude317
Mar 3, 2009 03:09 AM
VWkila
11
May 24, 2005 10:46 AM
