Whats needed to finish my setup..
Old Dec 12, 2002 | 09:27 AM
vtec.dc2's Avatar
Default Whats needed to finish my setup..
Below is the setup I plan to run on my car.
It seems to me I listed almost everything, what else is there to get? Its the small parts I'm not sure about.. Or are they already listed in there?
Things I got:
- Stock B18C5 Engine
- InlinePro T3 Stainless Steel Manifold
- 63.5mm carsound Cat and Exhaust
- RC 370cc Injectors
- AEM Fuel Pressure Regulator
- Hondata Stage 2
Things I need to purchase:
- Turbocharger (T3 S60 or small T3-T4)
- Air filter
- Custom Down Pipe
- HKS SS BOV with Flange
- Tial 35mm Wastegate (4.35psi Spring)
- Greddy Intercooler Kit for Type R? or LS? (not sure which model to get)
- Custom Charge Pipe?
- Walbro 255 High Pressure Fuel Pump
- Stainless Steel Feed/Return Lines Assembly
- Thermal flex hose's and connectors. T-bolt clamps
- Gaskets (oil pan, exhaust manifold..)
- Greddy/Apexi Turbo Timer
- Electronic Boost Controller (undecided on the brand)
- Electronic Boost Gauge (undecided on the brand)
- Electronic Fuel Pressure Gauge(undecided on the brand)
- Electronic EGT Gauge (undecided on the brand)
- Electronic Oil Pressure Gauge) (undecided on the brand)
- Electronic Oil Temperature Gauge (undecided on the brand)
- Gauge Mounts (undecided on the brand)
- Hondata Boost Option upgrade
[Modified by vtec.dc2, 6:41 PM 12/12/2002]
[Modified by vtec.dc2, 12:04 PM 12/13/2002]
[Modified by vtec.dc2, 2:33 PM 12/13/2002]
Old Dec 12, 2002 | 09:58 AM
4-banging's Avatar
Default Re: Whats needed to finish my setup.. (vtec.dc2)
do you know what the difference between the Inline Pro t3 & t4 manifold is?
Can you keep your a/c?
oh and that list of goodies is excellent!
Old Dec 12, 2002 | 10:00 AM
vtec.dc2's Avatar
Default Re: Whats needed to finish my setup.. (4-banging)
t3 is to fit t3 turbos, if its t3/t4 hybrid then it should work, it its t4, then you need t4 manifold, you can keep ac with t3 manifold, but don't know if the same for t4
Old Dec 12, 2002 | 02:33 PM
swrdply400mrelay's Avatar
How many psi do you plan to run?
[Modified by swrdply400mrelay, 11:34 PM 12/12/2002]
Old Dec 12, 2002 | 02:35 PM
vtec.dc2's Avatar
Default Re: Whats needed to finish my setup.. (swrdply400mrelay)
about 4.35-4.5psi
[Modified by vtec.dc2, 6:39 PM 12/12/2002]
Old Dec 12, 2002 | 02:43 PM
vtec.dc2's Avatar
had it updated, i placed to many parts in there...
[Modified by vtec.dc2, 6:50 PM 12/12/2002]
Old Dec 12, 2002 | 04:00 PM
vtec.dc2's Avatar
anyone?
Old Dec 12, 2002 | 04:34 PM
sutrusu's Avatar
i'm selling a drag intercooler! click the link in my sig!!!!
Old Dec 12, 2002 | 07:25 PM
vtec.dc2's Avatar
Default Re: Whats needed to finish my setup.. (sutrusu)
thanks, will check the link
can anyone help with my setup?
Old Dec 12, 2002 | 09:32 PM
vtec.dc2's Avatar
top
Old Dec 12, 2002 | 10:50 PM
Bspec18's Avatar
It seems you have all the essentials.... except a good oil line kit. Thermal flex hose's and connectors. T-bolt clamps. Do you have the wiring harnesses for the injectors ?
Old Dec 13, 2002 | 08:07 AM
vtec.dc2's Avatar
Default Re: Whats needed to finish my setup.. (Bspec18)
Injectors are already installed, I been running the on all motor setup. I added Thermal flex hose's and connectors. T-bolt clamps. Thanks for the help
Any other stuff, its minor stuff I want to consider ahead of time.
Old Dec 13, 2002 | 09:25 AM
camp1320.com's Avatar
hey i got turbos, fuel pump, and piping and intercooler kit... im or e mail me..also i have 255lph intank pumps in stock,i got Hoilday specials courtesy of RevHard Mfg for the year of year sale..
Old Dec 13, 2002 | 09:49 AM
vtec.dc2's Avatar
Default Re: Whats needed to finish my setup.. (camp1320.com)
thanks, i send IM..
back to the question... any help appreciated
Old Dec 13, 2002 | 10:22 AM
arjusmc's Avatar
don't forget gaskets(depending on the age of your motor) for the oil pan, exhaust mani, turbo. etc...
Old Dec 13, 2002 | 10:32 AM
vtec.dc2's Avatar
Default Re: Whats needed to finish my setup.. (arjusmc)
thanks, will add that to the list
Old Dec 13, 2002 | 12:19 PM
Boltz's Avatar
dude! you need a ecu conversion harness and a obd1 ecu..... im suprised no one said that yet...
Old Dec 13, 2002 | 12:30 PM
Muckman's Avatar
Moderator in Chief
SO you plan to just run low boost on stock internals? any plans for the bottom end?
Old Dec 13, 2002 | 02:46 PM
vtec.dc2's Avatar
Default Re: Whats needed to finish my setup.. (Civic420)
i'm already running hondata on my car, the only thing i need is upgrade to boost option
Old Dec 13, 2002 | 02:48 PM
vtec.dc2's Avatar
Default Re: Whats needed to finish my setup.. (Muckman)
yep, just low boost on stock internals.
almostboostedgsr
Feb 13, 2007 12:37 PM
93DituneEX
Feb 6, 2006 05:20 AM
Touge Tuning
Dec 10, 2004 10:34 PM
B00ST2nR
Jun 27, 2004 12:57 PM
pub
Dec 2, 2002 07:13 PM
