What are you guys using to cut the block?
Old Jul 21, 2002 | 08:00 AM
Integra_Boi's Avatar
New User
Default What are you guys using to cut the block?
I used a dremel to cut the fan.. but i dont have a clue what would cut thru the block... thanks
Old Jul 21, 2002 | 08:31 AM
HXMan's Avatar
Default Re: What are you guys using to cut the block? (Integra_Boi)
I used a big *** industrial air grinder, with grinder tip. It drained my 22 gal air tank in about 30 seconds!
Old Jul 21, 2002 | 08:44 AM
Cwest EK's Avatar
you mean the webbing?? I used a dremel with a cut-off wheel..took me about 4 wheels and about 30 minutes but it got the job done
Old Jul 21, 2002 | 09:30 AM
GSRwBOOST's Avatar
Default Re: What are you guys using to cut the block? (Cwest EK)
All I had was a rusty pocket knife.. kinda like the one McGyver uses on that TV show...
Old Jul 21, 2002 | 09:36 AM
93LSivic's Avatar
Default Re: What are you guys using to cut the block? (GSRwBOOST)
An electric drill and a metal grinding bit. Took about 2 minutes.
Old Jul 21, 2002 | 09:42 AM
filetofit
Guest
Posts: n/a
Default Re: What are you guys using to cut the block? (93LSivic)
A Dewalt 4 and 1/2 inch grinder with a cutoff wheel running at 12,000 rpm. Fast as hell. Dremels =
Old Jul 21, 2002 | 09:44 AM
Brad's Avatar
I used a sawzall to take out big chunks and an angle grinder to make it smooth.
Brad
Old Jul 21, 2002 | 10:05 AM
civictypenos's Avatar
Default Re: What are you guys using to cut the block? (Brad)
why not use a $20 4" angle grinder from the ho depot,thats what i used,took about 1 minute to cut her down and out,plus i use the grinder for all sorts of stuff.
Old Jul 21, 2002 | 10:19 AM
Flamenco-T's Avatar
Default Re: What are you guys using to cut the block? (civictypenos)
3/8" titanium drill bit and a smaller ones to smooth out the cuts..
took me 15 minutes..
do a search, under Flamenco-T, I have answered to this Q's a few times already...
Old Jul 21, 2002 | 10:51 AM
New User
Default Re: What are you guys using to cut the block? (C5_ALLMOTOR)
i had to buy two drill bitz to drill out the turbo... one titanium and one blue moil or something like that... theres this plate that sticks out under the b20 sign.. you guys just drilling it out?
Old Jul 21, 2002 | 10:56 AM
Full-Race Geoff's Avatar
Default Re: What are you guys using to cut the block? (filetofit)
angle grinders
with a carbide embedded abrasive wheel, its the best tool i own. ( actually i have 3)
Old Jul 21, 2002 | 11:20 AM
Ri5e's Avatar
Default Re: What are you guys using to cut the block? (FFgeoff)
I used my bare hands
Old Jul 21, 2002 | 11:37 AM
New User
Default Re: What are you guys using to cut the block? (BG Boost)
sureee BGboostt... u said u were gonna come up and help me.. what happen
PissedoffHONDA
May 23, 2008 08:21 AM
THEUSED
Apr 15, 2005 02:01 PM
D-booster
Jun 24, 2004 09:13 AM
5STAR3
Aug 15, 2002 02:41 AM
T4sol
May 21, 2002 08:07 AM
