What wastegate spring ???? Big Boost
Old Mar 4, 2005 | 09:58 AM
g2turbo's Avatar
Default What wastegate spring ???? Big Boost
Im trying to decide what wastegate spring to run in my setup. When its time to tune i will be doing both pump and race on the same day. I want to be able to run 28lbs if necessary( to reach ~550 whp) when I get tuned. What is a good starting spring that will be able to hold this much boost with a controller,
wastegate is a 38mm tial,
what are you guys using/?
Old Mar 4, 2005 | 10:35 AM
b18bturbo's Avatar
Default Re: What wastegate spring ???? Big Boost (g2turbo)
i would use the 1.0bar spring should be plenty to get you there easily
Old Mar 4, 2005 | 10:40 AM
g2turbo's Avatar
Default Re: What wastegate spring ???? Big Boost (b18bturbo)
The only problem that i forsee with using that spring is that the car will immediately have to start tuning at 14 lbs. And the turbo Im running will probably be ~400 whp on this boost level. Im at 10:1 compression and kinda wanted to keep power ~350 whp on pump. I know its hard to guess what boost level with make that power.
Old Mar 4, 2005 | 10:44 AM
s2kdre's Avatar
you should start tuning with a 10psi spring. And work your way up.
Old Mar 4, 2005 | 10:47 AM
g2turbo's Avatar
Default Re: What wastegate spring ???? Big Boost (jdmhonda)
I guess my real question then, is will a 7-10 lb spring be able to hold 28lbs with use of a boost controller?
Old Mar 4, 2005 | 10:50 AM
b18bturbo's Avatar
it should be able to do it on .8bar spring easily but most i seen are done on the 1.0bar and higher springs
Old Mar 4, 2005 | 10:55 AM
Evanmb44's Avatar
since you are going to be running race gas, which is leaded, you will need to get the tial spring that is made for running leaded fuel.
Old Mar 4, 2005 | 11:03 AM
g2turbo's Avatar
Default Re: What wastegate spring ???? Big Boost (Evanmb44)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evanmb44 &raquo;</TD></TR><TR><TD CLASS="quote">since you are going to be running race gas, which is leaded, you will need to get the tial spring that is made for running leaded fuel.</TD></TR></TABLE>
I think you are referring to the actual valve. Im not gonna run race gas all the time so im not very concerned with changing the valve.
Old Mar 4, 2005 | 06:04 PM
platinum00's Avatar
im pretty sure that the spring will be efficient up to double the spring rate. at that point it could start to flutter at higher RPM's
Old Mar 4, 2005 | 10:59 PM
PrettyLude's Avatar
Default Re: What wastegate spring ???? Big Boost (platinum00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure that the spring will be efficient up to double the spring rate. at that point it could start to flutter at higher RPM's</TD></TR></TABLE>
Old Mar 4, 2005 | 11:07 PM
TurboTegB18c's Avatar
Default Re: What wastegate spring ???? Big Boost (PrettyLude)
I ran up to 28psi on a tial 10psi spring and the boost held perfect. I was running the greddy profec spec 2 if it helps.
Old Mar 5, 2005 | 04:07 AM
liam821's Avatar
25 Year Member
Default Re: What wastegate spring ???? Big Boost (TurboTegB18c)
I also run a 10psi spring and it holds boost just fine. I wouldnt go any smaller then that tho.
Generally speaking, the larger the spring, the easier it will be for your boost controller to control greater amounts of pressure.
liam
dunkd
Feb 3, 2005 11:45 AM
LSEGHATCH
Dec 15, 2004 10:51 PM
TurboCoop
May 19, 2004 12:21 PM
gdrum
Feb 24, 2004 01:55 PM
Turbo_Teg
Jan 14, 2002 07:35 PM
