what vortech calibration kit should i use for the fmu with rc 310cc injectors?
what comes standard with the vortech fmu? is it 12:1? should i purchase to recalibration kit and which should i use? 10:1 or 8:1 with the 310's? is it difficult to swap out? and will this cure my TOO rich a/f ratio? thanks.
Re: what vortech calibration kit should i use for the fmu with rc 310cc injectors? (TurboInteg95)
thanks for the reply guys. i have changed my mind and i'm thinking of dumping my vortech for a cartech through a lot of people's recommendations. the question here is, would i need a cartech since it is adjustable, if i have a fpr and afc? not a s-afc but first gen afc. thanks
Re: what vortech calibration kit should i use for the fmu with rc 310cc injectors? (boostedeg6)
you will still need the cartech or vortech to compensate for boost pressure
Re: what vortech calibration kit should i use for the fmu with rc 310cc injectors? (9psiLsT)
yeah, i understand that but, my question is, since i have a bosch adjustable fpr and an apexi afc with the vortech, should i stick with the vortech since i have these other "band aids" or just get a cartech even though i have these other products that are adjustable as well?
and for anyone, what is the proper fuel pressure at idle for a 94 ls with 310cc's. mine is at 50 psi. is this too rich or lean?
