What type of injectors are these?
Old Jan 26, 2009 | 09:23 AM
mtkhalid's Avatar
Icon7 What type of injectors are these?
My apologies in advance if this is in the wrong section.
These injectors came on the car when i bought it. im doing a rebuild and need to know what kind/type of injectors are these. Also each injector had a resistor wired into it?
Every Injector reads INP - 018, on the other side it reads MDL 450 .
Any help would be appreciated.
Old Jan 26, 2009 | 09:28 AM
extralargenog's Avatar
Default Re: What type of injectors are these?
They look like 2nd gen DSM 450s... They have a multi spray pintle if they are.....
twkdCD595's Avatar
DSM 450cc injectors.
Old Jan 26, 2009 | 09:38 AM
tegman23's Avatar
Dsm blacktops are my guess also
Old Jan 26, 2009 | 10:07 AM
mtkhalid's Avatar
450 cc sounds decent. whats with the white resistors per injector ?
Old Jan 26, 2009 | 10:21 AM
Youll need a resistor box, or inlines to run them, unless in an accord or something that came with the box oem.
Old Jan 26, 2009 | 10:25 AM
mtkhalid's Avatar
thus the inline resistor for each of them. thank you for all the help. i dont want resistors or a box itself so i shall go to the RC 750 saturated.
twkdCD595's Avatar
They are peak n hold type injectors which require a resistor box to run correctly and not do damage to your injector driver in your ecu.
http://www.hondata.com/techlowohminjectors.html
edit: already got your answer, slow reply by me.
Old Jan 26, 2009 | 10:31 AM
mtkhalid's Avatar
is it possible that i could stick to these 450's if i am going for 450 hp.?
Old Jan 26, 2009 | 11:23 AM
HiProfile's Avatar
If you had 6 of them, yes. However, with 4 you'll only get ~300whp at most, and that assumes a walbro fuel pump at higher pressure.
750cc will get you 450whp safely, meaning about 80-90% duty cycle. With all current EMS's, you can also run 1k's w/o any negative issues. Bosch makes saturated 1k's that someone proved show gains just by better fuel atomization alone, but aren't as cheap as peak/hold 1k's.
Old Jan 26, 2009 | 08:53 PM
mtkhalid's Avatar
well then the tune will be at 300hp for safety reasons till i can upgrade. im in no hurry to blow my **** up
ceemarun
Aug 7, 2015 05:21 PM
b17a1crx
Sep 10, 2006 07:27 PM
Adriano
Oct 15, 2002 06:53 PM
