DSM injectors ?s
Old Oct 15, 2002 | 05:28 PM
Adriano's Avatar
Default DSM injectors ?s
what is needed to run DSM injectors in my 94 integra ls? Does it matter what year they are from? I have a set of 450 (??) from my old 93 talon. Im only going to put them in when my turbo is in. Thanks
Old Oct 15, 2002 | 05:33 PM
pelotudo's Avatar
Default Re: DSM injectors ?s (brryder)
You'll need resistor packs for them, and either a SAFC/SMC/Custom circuit. That's it, along with some tuning...
jB
Old Oct 15, 2002 | 06:51 PM
MikeMAN's Avatar
Default Re: DSM injectors ?s (PelowisheshewascoolTudo)
can someone explain resistor packs and their purpose? thanks..i understand everything else except resistor packs.
thanks,
mike
Old Oct 15, 2002 | 06:53 PM
pelotudo's Avatar
Default Re: DSM injectors ?s (MikeMAN)
Resistor packs are for Honda/Acura engies that use saturated injectors. DSM/EF injectors are peak/hold. You put in a resistor pack for each injector so that the newer engines can use the DSM injectors. If not, then you wont be able to work the injectors.
jB
ceemarun
Aug 7, 2015 05:21 PM
gents97civ
Oct 26, 2004 07:26 PM
