What Turbo should I get?!?!
Old May 6, 2005 | 09:47 AM
BME1986's Avatar
Default What Turbo should I get?!?!
Ok. So I am taking my car into the shop to get ls rods and vitara pistons put into my d16y7. I am going to be ordering a spoolin performance manifold and downpipe. I will be using uberdata as for my fuel managemant. The next decision is what turbo should I get? I would like to be able to make around 275whp at around 15psi. I was thinking a t3 with a 0.48 A/R and a 60 trim wheel. Will I be able to make that kinda power with tha turbo, or should I get something bigger. I do not want a t3/t4 however.
Old May 6, 2005 | 09:56 AM
burnt_rice's Avatar
Default Re: What Turbo should I get?!?! (BME1986)
why dont you try a 16g turbo from a lancer evo those turbo's are pretty nice on sohc setups it what i was going to use instead of my smaller 14b which is from a eclipse 2nd gen.....well anyway good luck with the setup..
Old May 6, 2005 | 09:59 AM
BME1986's Avatar
Default Re: What Turbo should I get?!?! (burnt_rice)
Because the spoolin manifolds come with a t3 flange. I could bolt up a 16g to the manifold I have now, but I want a new manifold. The evo turbos are a bit big. I would either go with a small or big 16g.
Old May 6, 2005 | 10:04 AM
clutch878's Avatar
gt35rs or sc60 those are the beast for you
Old May 6, 2005 | 10:09 AM
BME1986's Avatar
Default Re: What Turbo should I get?!?! (clutch878)
Those are to big and to expensive.
Old May 6, 2005 | 01:04 PM
BME1986's Avatar
anyone?
Old May 6, 2005 | 01:15 PM
rainmanef's Avatar
I could be wrong but I think the super 60s are good for that amount of power but at like 17psi. Someone correct me if I'm wrong.
Old May 6, 2005 | 01:16 PM
92civicb18b1's Avatar
You should be able to make 275 with a 48/60.
Just "make" it. Get a cheap *** 42/48 and find a .60 compressor housing and put them together.
Old May 6, 2005 | 01:18 PM
rmcdaniels's Avatar
Try figuring out your engine's pressure ratio and CFM at different RPM's, then you can map those values across the manufacturers compressor maps. Thet will tell you what turbo to use. Here's some information to help you do that:
http://www.turbosaturns.net/ar...s.htm
http://www.turbosaturns.net/ar...2.htm
Old May 6, 2005 | 01:28 PM
BME1986's Avatar
Default Re: What Turbo should I get?!?! (rmcdaniels)
Something like
this
http://cgi.ebay.com/ebaymotors...=WDVW
with this
http://cgi.ebay.com/ebaymotors...&rd=1
Old May 6, 2005 | 05:30 PM
yes, but you can find a 42/48 a lot cheaper than that. I paid like 100 plus shipping for mine.
Old May 6, 2005 | 09:46 PM
BME1986's Avatar
Default Re: What Turbo should I get?!?! (92civicb18b1)
I think I got a t3 60 trim off of turbod for $110 + shipping.
95LS1t
Jul 12, 2009 06:40 PM
dohcMONSTER
Jun 4, 2004 06:15 AM
JonnyCoupe
Apr 18, 2004 01:53 PM
1SIKCRX
Oct 9, 2003 08:13 PM
b18cls1
Sep 18, 2003 03:19 PM
