Which spark plugs for my GSR-T
I need to get some spark plugs tomorrow for my car. Which ones would be the best for a turbo gsr.
If someone could provide a part # too that would be greatly appreciated. I appreciate the help
how much should i gap them?
Re: (newgsrdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsrdriver »</TD></TR><TR><TD CLASS="quote">I run BKR7E's as well...3330.
3330's are bcp's not bkr's sucka!
Re: (FlamingEJ20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlamingEJ20 »</TD></TR><TR><TD CLASS="quote">bkr7e 's...NGK that is </TD></TR></TABLE>
gapped .028
gapped .028
Re: (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">
3330's are bcp's not bkr's sucka!</TD></TR></TABLE>
My baaaaaaaad...then help a brotha out and tell me what the BKR7E's are?
Nevermind, theyre 6097's
I always mix the 2!
I always mix the 2!
Re: Which spark plugs for my GSR-T (Turboteggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turboteggy »</TD></TR><TR><TD CLASS="quote">NGK BCPR7ES
I gap mine at around .030" depends on how much boost you gonna run. Less gap for more boost.</TD></TR></TABLE>
Ill be running 7.5psi.
What would you guys suggest I gap them at considering that, I plan on around 250whp +/-....conservative tune.
thanks for all the help thus far
Re: Which spark plugs for my GSR-T (92HB_HB)
I ran 3330's on 20psi of boost gapped to .025 with 425whp. Most of you B series guys should be fine with a .026-.028 gap with 15psi of boost.
I believe some people have gotten away with 500whp using these.
Moderator
none of you guys run 9 series. like the 5238's
That heat range is actually too cold. EGTs drop too low, and run tons too rich. You've got to run a LOT of boost to warrant using 2 steps colder like that. I mean RACE APPLICATIONS
Re: Which spark plugs for my GSR-T (choytim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by choytim »</TD></TR><TR><TD CLASS="quote">Where to buy these plugs? Anyone have a set for sale?</TD></TR></TABLE>
got mine from pitcrew. couldn't find it at pepboys, kragens, autozone....
i use the bcpr
edit: think i remember reading they had em at napa. you can give em a call.
Modified by GSRrR at 6:00 AM 5/25/2004
i use the bcpr
Re: Which spark plugs for my GSR-T (GSRrR)
i just ordered mine from advanced auto. they didn't have them in stock but overnight delivery got them there the next day for an easy pickup.
NGK BCPR7ES is what I am using. at a .30 gap.
Re: (TurboHybridEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboHybridEG6 »</TD></TR><TR><TD CLASS="quote">zex spark plugs... of da hooooooook 10 psi
nOOOOOOO!!!!!! dont use those, there bad.
Landon
Landon
gdrum
10-27-2003 05:48 AM
