what size injector for 10 to 15 lbs of boost?
Re: what size injector for 10 to 15 lbs of boost? (MysteriousGSR)
i second that. what other fuel mods will you be running?
[Modified by GudeH23a, 1:46 AM 3/28/2003]
i wanna run between 10 to 15 lbs so would 440's be enough ?
Unless this is 10-15lbs from a T66...
Re: what size injector for 10 to 15 lbs of boost? (shadowdawn)
on a t3/t4 turbo the 440cc will be fine with a HI flow fuel pump at about 12lbs/psi. just to be safe get bigger injectors cus ADRENLIN will make you crack up the boost and you can tune down the injectors but cant tune beyond the limts of the injectors.. i have SEMIEN and RC/LUCAS blanks..im or email me
