Help!!!! Detonation
Old Apr 25, 2002 | 09:08 AM
Vtec integra's Avatar
Default Help!!!! Detonation
I ran my car at the track last weekend without the toda b's and i just straight detonated.
what can be the cause of this problem?
i'm still running 270 injectors and the feul pressure is at about 40 psi.
i even reprogrammed the v-afc to runa little richer and still detonation
i turned up the feul pressure to 40 psi ad it has run a little bit better
only detonating after about 7500 rpm or so.
could it be my o2 sensor?
i know its detonation because i pulled out the plugs at the track
and they were grayish very grayish and white
i am running denso iridium plugs with the blaster coil
any help will be helpful
[Modified by Vtec integra, 10:12 AM 4/25/2002]
Old Apr 25, 2002 | 09:15 AM
Evil DOHC's Avatar
Default Re: Help!!!! Detonation (Vtec integra)
Adjust your timing!!!
EVIL
Old Apr 26, 2002 | 07:32 AM
Default Re: Help!!!! Detonation (Evil GS-R)
which timing? timing belt? or the distributor?
Old Apr 26, 2002 | 07:53 AM
TGUNNER's Avatar
Fuel pressure to 40psi?? Isnt stock setting 42psi?? and you have bigger injectors, they are probally not getting enough fuel.. try to raise fuel pressure to like 45psi... and your ignition timing try retarding it..
Old Apr 26, 2002 | 09:06 AM
neo1z's Avatar
Default Re: Help!!!! Detonation (TGUNNER)
definitely retard the timing -- or check it at least to make sure its within spec
Old Apr 26, 2002 | 03:24 PM
StinkyTofu's Avatar
Default Re: Help!!!! Detonation (neo1z)
if you went back to stock cams, won't the compression be a little higher?
Old Apr 26, 2002 | 04:10 PM
Fooser's Avatar
Default Re: Help!!!! Detonation (StinkyTofu)
Up your octane
Old Apr 26, 2002 | 04:12 PM
sek311's Avatar
check your timing, are your injectors peak hold?
Old Apr 26, 2002 | 04:41 PM
dubster99's Avatar
Cams have nothing to do with compression ratio....
Old Apr 26, 2002 | 05:14 PM
StinkyTofu's Avatar
Default Re: Help!!!! Detonation (dubster99)
Really they don't? I dunno...i just thought that since toda spec b's have more lift, your total compression will be reduced. The valve will open more, and you will lose more compression. Or is that called static compression? I have no idea, but that is one of the reasons why you need high compression for agressive cams such as the toda B's, to make up for the loss.
Old Apr 26, 2002 | 05:18 PM
sek311's Avatar
If your O2 took a **** then you would have a check engine like.. also the ecu will rich your mixture if you have a fouled O2. If youre running a OBDII computer it'll show a O2 code along with a mixture too rich code.
Old Apr 26, 2002 | 05:37 PM
randyman's Avatar
New User
Default Re: Help!!!! Detonation (sek311)
it is essential that u upgrade ur injectors to 310 cc's. ur 270's are being over-worked and ur pistons are paying for it.
Old Apr 26, 2002 | 05:55 PM
Halo's Avatar
Default Re: Help!!!! Detonation (randyman)
dam sorry to hear that man, detonation is my worst nightmare, I am pinging like crazy as is. BTW- does anyone know what LS injectors flow at?
Old Apr 26, 2002 | 07:36 PM
my timing is at about 2 degrees retarded.
as for feul pressure this is the first time i really
raised it because i had no problems before.
not til at the track. but i'll be working on it tomorrow
thanks guys i will be updating sometime this weekend
Old Apr 27, 2002 | 12:34 AM
Ramocheese's Avatar
Do the iridium plugs actually help that much? I'm a fan of NGK OEM plugs, maybe a range colder than stock. 9 out of 10 times that solves problems of pinging/knocking. I would also run some combustion chamber cleaner through your motor to get rid of any possible carbon deposits on the pistons. Carbon can always promote detonation.
If that doesn't fix it, I would check your timing from the distributor, and zero your VAFC out so it runs stock a/f ratio. If it still seems like it's detonating, it could be bad gas, or some kind of igniton problem.
Old Apr 27, 2002 | 12:40 AM
dubster99's Avatar
Default Re: Help!!!! Detonation (Ramocheese)
If you're running 12.5:1, you better run race gas or a lot of timing retard....
Old Apr 27, 2002 | 01:28 AM
CKim's Avatar
My thoughts exactly.
Old Apr 27, 2002 | 07:47 AM
Rory Breaker's Avatar
If you're detonating so bad, step one would be to stop driving it.
Step 2 would be to pull back your ignition timing.
Old Apr 27, 2002 | 08:17 PM
ingrate's Avatar
25 Year Member
what you are talking about is dynamic compression. static compression is just a number ratio
Old Apr 27, 2002 | 08:59 PM
dubster99's Avatar
Default Re: Help!!!! Detonation (In7egrity)
yes....static compression is when the engine is not moving. Dynamic is when the motor is moving.
Luisrivera25
15
Dec 7, 2011 12:44 PM
lsdc4
Apr 20, 2009 07:55 AM
lsvtec_hatchback
Mar 25, 2009 08:33 PM
13secondmonster
Jul 27, 2004 05:06 PM
RaVAGE00
Oct 12, 2002 05:01 AM
