running lean
Old Jul 1, 2002 | 01:55 PM
guest's Avatar
Default running lean
well i have a drag kit on my d16z6 with the 12:1 fmu and a inline pump and am running 5lbs. but i seem to be running lean my plugs are almost ghost white. anyone know what the problem could be. do you think it could be my fmu. if it is how do you check if it is good or bad.
Old Jul 1, 2002 | 03:01 PM
technine's Avatar
Default Re: running lean (guest)
I keep hereing about static fuel pressure causing lean conditions from 0 to 3psi of boost. Try raising your static fuel pressure a bit and see if it helps. Do you here any detonation? Did you retard/advance your timing? Do you have any hesitation or drivability problems? Need more to go on.
Old Jul 1, 2002 | 03:05 PM
Etylorcen's Avatar
Default Re: running lean (technine)
How long have you been running on the plugs?
Old Jul 1, 2002 | 03:11 PM
guest's Avatar
Default Re: running lean (Etylorcen)
i do not hear any detonation. my timing is retarded 2 degrees. my plugs are a week old and gapped to .32. i also have msd ignition.
spoon063
May 13, 2003 03:05 PM
DLOTYPER
Jan 28, 2003 11:19 AM
Guitarzann
Jan 21, 2002 02:59 PM
DragII
Jul 30, 2001 09:02 AM
