What is my timing should be at?
Old Jan 27, 2002 | 05:17 PM
SpeedracerS4's Avatar
Default What is my timing should be at?
Well got done putting the drag kit on last night, took me about 10hrs. I have a mugen obd1 ecu so I back down the timing to about 8 degree. It pulls hard for a stock b16 on 5lbs, but I want to advance the timing more. What my timing should be w/ that computer? or should I switch to stock ecu? any input welcome! thanks
Old Jan 27, 2002 | 05:20 PM
b18bturbo's Avatar
Default Re: What is my timing should be at? (SpeedracerS4)
shoudl only retard about 3-4 degrees not much more that than take it back to around 12-14.
Old Jan 27, 2002 | 10:16 PM
01geeser's Avatar
New User
Default Re: What is my timing should be at? (b18bturbo)
watch out with that allmotor ecu. take it easy on the motor until you get a different ecu.
Old Jan 27, 2002 | 10:57 PM
HotRodTeg's Avatar
Default Re: What is my timing should be at? (01geeser)
Yeah u should run a stock ECU cause the mugen one runs way to much timing at high rpms witch is not great for turbo motors. Also if u do decide to run a stock ecu the timing shoud be around 12-14 degrees.
---SPEED-DEMON---
Engine Management and Tuning
Apr 1, 2009 12:14 AM
wilsel
Mar 23, 2005 05:37 PM
01PYTypeR#1140
Jul 17, 2001 06:33 PM
BlackGSR
Jul 11, 2001 05:58 PM
