Reset ECU = Reset Timing?
Old Mar 23, 2005 | 03:02 PM
wilsel's Avatar
Default Reset ECU = Reset Timing?
I'm running a JRSC, and I had to replace my ECU. Now it doesn't feel as strong. Do I need to retard my ignition timing again since this is a different ECU?
Old Mar 23, 2005 | 03:55 PM
wilsel's Avatar
Default Re: Reset ECU = Reset Timing? (wilsel)
ttt
Old Mar 23, 2005 | 04:00 PM
tegon-gsr's Avatar
was your ecu chiped or was your timming retared under the hood?
Old Mar 23, 2005 | 05:34 PM
wilsel's Avatar
Default Re: Reset ECU = Reset Timing? (tegon-gsr)
both are stock ecus. The timing was adjusted with distributor, but you have to jumper the service connector for the ecu to set the timing that way.
Old Mar 23, 2005 | 05:37 PM
.::Lee::.'s Avatar
The only reason you jump the service connector is to get the ecu to stop messing with the timing while you are adjusting it. You can actually adjust the timing without doing it, it's just not as accurate.
If you have not adjusted your distributor at all, then your timing should still be retarded to where it was before.
JohnnyEF
Feb 10, 2010 06:09 PM
---SPEED-DEMON---
Engine Management and Tuning
Apr 1, 2009 12:14 AM
JdmIntegra98
Jul 2, 2003 10:10 PM
cruzersi99
Jan 29, 2003 09:13 AM
01PYTypeR#1140
Jul 17, 2001 06:33 PM
