What is that max power that.....
Old Apr 16, 2007 | 03:30 AM
EX-T's Avatar
Default What is that max power that.....
...the td04h 15g turbo that comes with the d16z6 GReddy kit can make?
Old Apr 16, 2007 | 03:39 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: What is that max power that..... (EX-T)
depends on the tuner alot cant say i have much exp with single cam kits. sry.
Old Apr 16, 2007 | 05:52 AM
Joseph Davis's Avatar
You'll hit ~240 whp before that turbo is maxxed out. It really has nothing to do with the tuner (unless something is horribly horribly wrong) and more to do with what dyno the car is strapped to.
Old Apr 16, 2007 | 06:10 AM
Mr. Badwrench
Default Re: What is that max power that..... (Joseph Davis)
what i was saying is that some tuners are a little better at fine tuning.
for instance:
my car 84mm b16 t3t67ho 1200cc injectors.
i made 540 on it.
friends car
81mm b16 my turbo 1000 cc injectors
another tuner made 594 at the same boost i made 540 on.
all i am saying is that one tuner can make xxx hp. a great tuner may make more. thats all i am saying. both were tuned on a dynapac.
not stepping on toes.
Old Apr 16, 2007 | 06:16 AM
SPOOLINmatt's Avatar
Default Re: What is that max power that..... (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">what i was saying is that some tuners are a little better at fine tuning.
for instance:
i made 540 on it.
friends car
not stepping on toes. </TD></TR></TABLE>
and what turbo did your friend have, engine health and setup plays a big role in that too, whether its a new build or not.
Old Apr 16, 2007 | 06:24 AM
Mr. Badwrench
Default Re: What is that max power that..... (SPOOLINmatt)
my turbo the same one i used.
the only thing i cant account for is engine health. mine was 3 years old.
same basic setup we used my turbo and intercooler
mine / his
hondata s200b / neptune
84mm sleeved b16 / stock bore b16
9:1 je pistons / 9:1 ross pistons
stock cranks
gsr cams / itr intake-gsr exh
vic x manifold / skunk 2
f-r ram horn / love fab
3" dp on both.
again not starting an argument, my bore should have made up for engine health. at the end of the season, i had 180 across the board.
the difference is where afr's were. my tuner, being his first time tuning over 750's, the afr's were conservative. low 11's.
his tuner, a well known one here. no name dropping, got it done faster, cleaner and made more pwer at the same boost.
Old Apr 16, 2007 | 06:28 AM
Those differences could be caused by any number of things - different dyno, your engine builder was drunk when bored your #4 cylinder and as such the rings aren't sealling as well, your turbo manifold has less of an OMG JDM shallow merge to it than your buddy's does, etc.
I generally disregard hp per psi numbers. If the car is running correctly then they mean nothing. 540 whp in a stock weight 88-89 ED chassis is a solid nine second car, unless you're still fighting the T67 being a laggy pile that spins down between shifts, or the powerband is too peaky so you aren't making good consistent power across your operating rpm range.
For the case in point, the 15G, it flows about 24 lbs/min worth of air. This translates to about 240 whp. If flow through the engine (D-series, I ASSume) is restrictive, you make this power at 17-18 psi. If flow through the engine is not, you make this power at 14-15 psi. The brass tacks of the situation is that it's going to provide at most 24 lbs of air, with maybe some small single digit % increases if you spent $3000 in volumetric efficiency parts like merge manifolds and big plenum IMs, in which case you could have just spent $400 more on a much bigger turbo and made a lot more power.
Last T67 car I raced, I ASSumed 650-700. When I didn't smell racegas I ASSumed 450ish as well as peaky and hard to drive, and unlimbered my wallet. At no point in time did I care what fancy pants crap was bolted to the car aside from the turbo itself, as that is where your power comes from.
Old Apr 16, 2007 | 07:28 AM
nasteboyii's Avatar
sorry mikey,
u missing one important difference
10.6 compression ross
not 9. to 1
and age is mine was older bout 4yrs old now (4-5)cant remember
but has only been boosted for bout 3yrs
hope this helps
CR can make a big difference in power
Dan
Old Apr 16, 2007 | 07:30 AM
Mr. Badwrench
Default Re: What is that max power that..... (nasteboyii)
either i missed that or just flat out forgot.
I STAND CORRECTED.
Old Apr 16, 2007 | 08:46 PM
EX-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joseph Davis &raquo;</TD></TR><TR><TD CLASS="quote">Those differences could be caused by any number of things - different dyno, your engine builder was drunk when bored your #4 cylinder and as such the rings aren't sealling as well, your turbo manifold has less of an OMG JDM shallow merge to it than your buddy's does, etc.
Last T67 car I raced, I ASSumed 650-700. When I didn't smell racegas I ASSumed 450ish as well as peaky and hard to drive, and unlimbered my wallet. At no point in time did I care what fancy pants crap was bolted to the car aside from the turbo itself, as that is where your power comes from.</TD></TR></TABLE>
Time to sell the GReddy and get a bigger snail!!!!!
99_red_si
Mar 1, 2008 09:14 PM
ohmigo0lay
Mar 18, 2007 06:34 AM
borne
Sep 19, 2005 07:20 AM
quik sol
Jan 14, 2005 07:22 PM
colt45turbo
Apr 15, 2003 12:45 PM
