what the hell is turbo lag?
pretty sure turbo lag is the time it takes for your turbo to spool back up between shifts
larger turbo = more power but more lag
smaller turbo = not as much power but less lag
hope that helps and if im compleatly wrong.. sorry..
turbo lag normally occurs on small engines with large turbos. turbo lag is when an engine does not produce enough exhaust flow to spool up a turbo until higher rpms. since the large turbo does not spool quickly it does not give you power down low in the rpm range and this is known as turbo lag.
It's the "wait for it, wait for it .... AAHHHHH" feeling in a turbo car.
Kind of like when yo_ eh... that's not really appropriate.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday »</TD></TR><TR><TD CLASS="quote">It's the "wait for it, wait for it .... AAHHHHH" feeling in a turbo car.
Kind of like when yo_ eh... that's not really appropriate.</TD></TR></TABLE>lol's
perfect explanation
perfect explanation
Drive an SS/WS6/Mustang V8, keep it in 3rd gear on the freeway, then punch it. Immediately pushed into your seat.
Take a heavy, stock GSR, and [from a stop] drive up to 65mph in 2nd gear. Note 'vtec' warping you to light speed near the end (
The latter is most like turbo lag. On a Honda, the turbo's shaft spins around 100,000-150,000 rpm's in boost, yet just a few thousand while cruising. Some are too big on hondas to spin at idle. Blink your eye once, and a spooled turbo has spun 500 times around
That should give you an idea what causes turbo lag. <U>Engine load determines energy put into the turbine, and shifting/cruising/idling are all low-load conditions, WOT is high-load</U>, as is taller gearing to an extent.
)The latter is most like turbo lag. On a Honda, the turbo's shaft spins around 100,000-150,000 rpm's in boost, yet just a few thousand while cruising. Some are too big on hondas to spin at idle. Blink your eye once, and a spooled turbo has spun 500 times around
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronISthrowed »</TD></TR><TR><TD CLASS="quote">Turbo lag was developed on Hondas to let the supercharged v8s get a head start during a race to make it more even.</TD></TR></TABLE>
signature material right there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atec »</TD></TR><TR><TD CLASS="quote">Turbo lag is the time it take from you hitting the throttle, to the combustion of the engine makes the turbo blow in fresh charge air
This is the only correct reply here. Everyone else is talking about spool rpm as if it were turbo lag. If you're too low in the rpm band, it doesn't matter how much gas you give it, it won't spool up. If you're past the minimum spool rpm after a shift, there is still a delay between hitting the gas and the turbo doing its job. That delay, and only that delay, is turbo lag.
Google search
Notice how none of those definitions mention getting it up to an rpm where you can spool up the turbo.
</TD></TR></TABLE>This is the only correct reply here. Everyone else is talking about spool rpm as if it were turbo lag. If you're too low in the rpm band, it doesn't matter how much gas you give it, it won't spool up. If you're past the minimum spool rpm after a shift, there is still a delay between hitting the gas and the turbo doing its job. That delay, and only that delay, is turbo lag.
Google search
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slogins »</TD></TR><TR><TD CLASS="quote">
signature material right there</TD></TR></TABLE>
haha thanks.
signature material right there</TD></TR></TABLE>haha thanks.
jabroni95gsr
May 14, 2003 01:10 AM
