What's the difference
Old Dec 7, 2006 | 03:27 PM
rdeezy78's Avatar
Default What's the difference
Is there a great difference in bb turbos and non-bb turbos. I know the bb prolly spool faster, but what's the real deal? I want to upgrade, but would like the 411 before i spend big $$
Old Dec 7, 2006 | 04:02 PM
urbansi's Avatar
Default Re: What's the difference (rdeezy78)
Directly from Garrett's website...
Journal Bearings vs. Ball Bearings
The journal bearing has long been the brawn of the turbocharger, however a ball-bearing cartridge is now an affordable technology advancement that provides significant performance improvements to the turbocharger.
Ball bearing innovation began as a result of work with the Garrett Motorsports group for several racing series where it received the term the ‘cartridge ball bearing’. The cartridge is a single sleeve system that contains a set of angular contact ball bearings on either end, whereas the traditional bearing system contains a set of journal bearings and a thrust bearing
Tests run on CART turbos have shown that ball-bearings have up to half of the power consumption of traditional bearings. The result is faster time to boost which translates into better drivability and acceleration.
Reduced Oil Flow – The ball bearing design reduces the required amount of oil required to provide adequate lubrication. This lower oil volume reduces the chance for seal leakage. Also, the ball bearing is more tolerant of marginal lube conditions, and diminishes the possibility of turbocharger failure on engine shut down.
Improved Rotordynamics and Durability – The ball bearing cartridge gives better damping and control over shaft motion, allowing enhanced reliability for both everyday and extreme driving conditions. In addition, the opposed angular contact bearing cartridge eliminates the need for the thrust bearing commonly a weak link in the turbo bearing system.
Competitor Ball Bearing Options – Another option one will find is a hybrid ball bearing. This consists of replacing only the compressor side journal bearing with a single angular contact ball bearing. Since the single bearing can only take thrust in one direction, a thrust bearing is still necessary and drag in the turbine side journal bearing is unchanged. With the Garrett ball bearing cartridge the rotor-group is entirely supported by the ball bearings, maximizing efficiency, performance, and durability.
Pretty much sums things up easliy. Basically you are paying for better spool/powerband in most cases.
Old Dec 7, 2006 | 04:06 PM
CRXDrew's Avatar
Default Re: What's the difference (urbansi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi &raquo;</TD></TR><TR><TD CLASS="quote">Directly from Garrett's website...
Basically you are paying for better spool/powerband in most cases.</TD></TR></TABLE>
Sums it up... just gotta see what the other cases are. Borg Warner and Extended Tip Wheels are really starting to represent.
Old Dec 7, 2006 | 04:08 PM
urbansi's Avatar
Default Re: What's the difference (CRXDrew)
And dont forget turbonetics GT KILLER
Old Dec 7, 2006 | 04:11 PM
CRXDrew's Avatar
OP: what are your goals? Just want more spool/wider powerband? Anything specific?
CKnight90
Aug 13, 2015 03:56 PM
Hellahflush
Mar 27, 2015 05:15 PM
NoWorry's
May 6, 2013 06:12 PM
jtbsurfer
Apr 30, 2007 03:12 PM
