What happens when injectors are wired backwards?
Old Jul 22, 2003 | 06:27 PM
Trac226's Avatar
Default What happens when injectors are wired backwards?
I recently put on some 450cc's. I thought I wired them in correctly the first time around, but then second guessed myself and switched the wiring to the resistor box. The car started up, but it sounded like it was misfiring. I then checked my VAFC setting and the engine selection was on 6 cylinders!
So I figured it was misfiring from that setting. Next I checked over the wiring and I concluded that I wired them in correctly the first time, so I switched the wires again.
Now, it sounds like my battery's low because the car won't crank over anymore, just a whine and die. I checked my plugs and there's fuel on them, but I'm not getting spark. Gonna boost the battery tonite.
I need some help, this whole install has been tough while trying to work 60+ hours!
I just want to know if start up would even be possible with the injectors wired backwards. Thanks.
Old Jul 22, 2003 | 06:47 PM
tommyten's Avatar
Default Re: What happens when injectors are wired backwards? (Trac226)
I was wondering the same thing
Old Jul 22, 2003 | 06:51 PM
Jared's Avatar
Don't DSM injectors have a + and - on the top? either way, they're wired the same way as the honda injectors are.
Old Jul 22, 2003 | 06:55 PM
meanteg's Avatar
New User
Default Re: What happens when injectors are wired backwards? (hatchling)
I don't know, but i'll risk myself. So do not take what i'm gonna say for granted.
The injector, being a solenoid, need curent pulses to open and close. So if you reverse the current in the injector's coil, it should reverse the closing / opening moment .
That seems logical to me. Correct me if i'm wrong.
Old Jul 23, 2003 | 09:57 AM
Trac226's Avatar
Default Re: What happens when injectors are wired backwards? (meanteg)
Started her up this morning, and injectors due fire up even when wired backwards. Meanteg's probably right that it reverses the pulses.
Idle's rough, still sounds like it's misfiring on one cylinder, no check engine lights though.
Need to get some air....open downpipe's killin me
Old Jul 23, 2003 | 10:18 AM
DSF's Avatar
DSF
Technically, an injector is a solenoid. They can't be wired backwards. The circuit is either complete or it's not. Injector open or closed. On or off.
Old Jul 23, 2003 | 10:41 AM
SuperTeg95's Avatar
Default Re: What happens when injectors are wired backwards? (DSF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSF &raquo;</TD></TR><TR><TD CLASS="quote">Technically, an injector is a solenoid. They can't be wired backwards. The circuit is either complete or it's not. Injector open or closed. On or off.</TD></TR></TABLE>
He is correct. There is no backwards.
Old Jul 23, 2003 | 11:05 AM
Trac226's Avatar
Default Re: What happens when injectors are wired backwards? (SuperTeg95)
The resistor box will just affect the incoming signal then..
Old Jul 23, 2003 | 11:43 AM
quikB18B's Avatar
Last year i put in some Rc injectors and wired backward(accident) and when i turned my car on it sounded like a friggen boat. It was misfiring sounded like ***. It drove but something was way wrong. I took the car to jotech and they tried several different things that didnt work. Finally it ended up being my ECU. Somehow it fried the ecu , i ended up just getting a obd1 ecu and doing the conversion.
Old Jul 23, 2003 | 12:20 PM
Trac226's Avatar
Default Re: What happens when injectors are wired backwards? (quikB18B)
Nooo, fried ecu does not sound good....
Old Jul 23, 2003 | 12:30 PM
quikB18B's Avatar
borrow a friends put in it, see if it elimates your problem. Atleast if it doesn't work the your diagnose didnt cost any money
cristegra09
May 14, 2009 08:52 AM
alfee
Jun 3, 2005 08:43 PM
yusoslo
Sep 25, 2004 07:41 PM
BlackB18CTeg
Jun 5, 2003 09:40 AM
JalopySiR
Mar 12, 2003 10:52 AM
