Rod Knock
Old Oct 27, 2002 | 09:25 PM
B20zvtecek's Avatar
Default Rod Knock
Ok one day i was commin home from work when i hear a somewhat knocking noise coming from my motor, it seems to be that one of my rod bearings have gone out, but not sure. It idles fine but when i rev up to about 3g or more the tapping noise gets louder and louder. Motor is a B18A-vtec. can someone tell me the problem is ? and the torque specs of the rods? Is it possible to change the bearings from only taking off the oil pan and what not?
Any help is appreiciated Thanks
Old Oct 28, 2002 | 01:35 AM
Zero2Sixty's Avatar
Default Re: Rod Knock (B20zvtecek)
You could try to replace your rod bearings by droping the oilpan but if the bearings messed up the crank then theres alot more work to be done. Or your valves could need an adjustment.
bseries_ben
Feb 13, 2007 04:53 AM
turboex
Aug 30, 2004 10:42 PM
B20zvtecek
Oct 28, 2002 07:11 AM
Mover
Jul 14, 2002 06:06 PM
