Name that wastegate!
Old Apr 17, 2004 | 03:27 AM
GSRswapandslow.
Guest
Posts: n/a
Default Name that wastegate!
i need help figuring out what kind of wastegate this is...
Old Apr 17, 2004 | 05:15 AM
turbopimp's Avatar
Default Re: Name that wastegate! (Ej6andslow)
Looks like a Carcraft. At least that is the name of the company that either manufactured or distributed it about 7 years ago. They were common on air cooled VW's back then. I would not trust that WG... I have personallly witnessed a B18 trash 3 cylinders due to that gate. Unless the design has been radically improved since then, I really think it would be ill advised to even consider using it... take it apart and judge for yourself - the diaphragm is not a rolling diaphragm or even convoluted for that matter - it's just a flat cut piece of low grade silicone same as you would find inside an FMU. In the aforementioned B18 the WG valve shaft seized in the closed position, you know what happened next...
Old Apr 17, 2004 | 05:23 AM
GSRswapandslow.
Guest
Posts: n/a
Default Re: (Ej6andslow)
it's not a carcraft
Old Apr 17, 2004 | 05:32 AM
turbopimp's Avatar
The pic you just posted is a Deltagate with a Carcraft billet top hat... check the cast base w/ the turbonetics logo on it... nothing more than a Deltagate with a cosmetically improved cap, internally it is the same as a Turbonetics unit. I don't know if the gate you originally inquired about is still available or not, but it was indeed sold by Carcraft in the 80's for air-cooled VW's and can be seen in the book "Turbomania" or something like that.
Old Apr 17, 2004 | 05:35 AM
GSRswapandslow.
Guest
Posts: n/a
this isn't THAT old
Old Apr 17, 2004 | 05:41 AM
GSRswapandslow.
Guest
Posts: n/a
but, i'll check into it farther.....and check that possibility
it was working excellently on the car it was removed from...and did so for a year at 354whp....but, i've seen deltagates hold up for a while too
thanks for the info
Old Apr 17, 2004 | 05:56 AM
turbopimp's Avatar
Well, here's what I can tell you. Don't hold me to this because it's been a long time, but I can say with 100% certainty that the cast iron base is identical to the unit that CC was selling back in the 80's. If I recall correctly the the diamond shaped flange is identical to exhaust port flange of the VW motor and the valve is actually a VW exhaust valve. The top hat underwent a revision. Originally it truely resembled a "top hat" as in something you'd wear on your head. Later they streamlined the cap to what is shown in your first post. The unit that I reported as failing had the nut which secured the valve to the diaphragm back out, as well as having the valve stem seize in the bronze valve guide. Best bet might be to contact CC about it, I'm pretty sure they'll have all your answers... but I'd still recommend just pulling the thing apart and judging the quality for yourself. As I said they may have improved the design since then, but somehow I doubt it. The diaphragm, if it is just a die cut flat piece, I would think that alone would dissuade anyone from using it.
Old Apr 17, 2004 | 06:14 AM
GSRswapandslow.
Guest
Posts: n/a
well, i'm N/A...i just picked this up for the hell of it...and was wondering about it
Old Apr 17, 2004 | 06:26 AM
turbopimp's Avatar
Ah, I see... best of luck to you on your project then. Boost =
Old Apr 17, 2004 | 06:27 AM
GSRswapandslow.
Guest
Posts: n/a
thanks for all the help and info!
Old Apr 18, 2004 | 03:26 AM
hondaboii's Avatar
dont know much..but quick guess...
ARC wastegate? do they even make wastegates? hehe..
Old Apr 18, 2004 | 05:57 AM
GSRswapandslow.
Guest
Posts: n/a
actually....ARC was my very first guess....but they are usually stamped with ARC on them...and i couldn't find any pictures to cross reference with
Old Apr 18, 2004 | 07:12 AM
macrosshn's Avatar
the son and the heir
What is Sheepdog?
Old Apr 19, 2004 | 11:39 AM
hondaboii's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej6andslow &raquo;</TD></TR><TR><TD CLASS="quote">actually....ARC was my very first guess....but they are usually stamped with ARC on them...and i couldn't find any pictures to cross reference with</TD></TR></TABLE>
oh, then im clueless about this! hahaha..good luck finding it out!
Old Apr 19, 2004 | 11:42 AM
matt_sb2000's Avatar
Default Re: (hondaboii)
Carcraft is like 10 minutes from my house.
Old Apr 28, 2004 | 04:07 AM
GSRswapandslow.
Guest
Posts: n/a
ok, i took it apart...and the diaphram was not flat...it was covulated
it also says dorman products on two parts of it...and then gives some serial numbers...
anyone know anythign about Dorman Products?!??!
Old Apr 29, 2004 | 03:29 AM
turbopimp's Avatar
Default Re: (GSRswapandslow.)
Dorman Products manufactures a bunch of stuff that can be found at such fine automotive institutions as Autozone, Pep Boys and Napa. I'm assuming the two pieces in question were found clamping the diaphragm? Kinda look like brass or copper colored steel stampings with a radiused lip? They are actually freeze plugs from a Chevy or some other domestic iron... If CC changed the diaphragm to a convoluted design when they redesigned the the cap, then hats off to them for product improvement. I still have the defunct CC unit laying around if you wanna see pics.
Old Apr 29, 2004 | 06:38 PM
GSRswapandslow.
Guest
Posts: n/a
please post pics....
it might be the car craft.....it does hvae a similar top hat i guess...but just no markings
and Dorman seems to make things for just about everyone...i was suprised after looking at their site...they're huge
the flanges are weird though, they are much smaller than a deltagate...
but i'll try to get a pic of hte diaphragm and post it up soon
Old Apr 29, 2004 | 07:13 PM
PHiZ's Avatar
Let's call it tony, tony is a good name.
-PHiZ
Old Apr 30, 2004 | 03:24 AM
GSRswapandslow.
Guest
Posts: n/a
then Tony it is!
Old Apr 30, 2004 | 07:17 PM
turbopimp's Avatar
I'll try to post pics this weekend after I dig this thing up...
Old Apr 30, 2004 | 08:52 PM
rioninja's Avatar
Default Re: Name that wastegate! (GSRswapandslow.)
Where did you pick tony up from anyhow?
Old May 1, 2004 | 02:20 AM
GSRswapandslow.
Guest
Posts: n/a
i guess that's just a cool name
so anyone wanna buy tony? he's house trained!
Old May 1, 2004 | 02:31 AM
Drew Peacock's Avatar
Dude tony sucks ****
Old May 1, 2004 | 07:21 AM
GSRswapandslow.
Guest
Posts: n/a
and why is that?
Adam_b16a
Aug 25, 2009 03:00 PM
Mr. Em1
Nov 4, 2008 12:04 PM
LSVTECTURBOTYPER
Dec 19, 2005 04:38 PM
smnowell
Feb 5, 2005 03:26 PM
Boostless97Lude
Jan 19, 2003 09:51 AM
