What are the drawback on a thicker head gasket.
Old Feb 10, 2004 | 03:55 PM
Sincere's Avatar
Default What are the drawbacks on a thicker head gasket.
I did a search and the information found was limited. I'm going to boost my 99-00 si on stock internals for now. I will be using a t3/t4 turbo. I was planing on doing 7 psi at the most untill i found out (on this board) that some people are running higher boost (on stock bottom) with a thicker head gasket. How reliable is this? Will i be able to get by with a thicker head gascket untill i work on the bottom end.
Any info will be apreciated.
Old Feb 10, 2004 | 04:05 PM
TravSi's Avatar
Default Re: What are the drawbacks on a thicker head gasket. (Sincere)
all it does is lower your compression and you will be able to run more boost, it would work....
Old Feb 10, 2004 | 04:27 PM
Fkned's Avatar
the drawbacks are loss of compression and quench.but it won't hurt power w/turbo
Old Feb 10, 2004 | 04:29 PM
TurboJesse
Guest
Posts: n/a
Default Re: What are the drawbacks on a thicker head gasket. (fkned)
i run one, ran 14psi on 93 oct. before, planning on running 18-20psi on c16 with the new setup
Old Feb 10, 2004 | 04:30 PM
Muckman's Avatar
Moderator in Chief
Can you explain quench area? I did a search and found very little threads and no explination.
Old Feb 10, 2004 | 06:52 PM
Bailhatch's Avatar
Default Re: What are the drawbacks on a thicker head gasket. (Muckman)
It's the area around the edge of the combustion chamber where the piston comes closer to the head at TDC. This forms pockets of air that get squished out into the chamber at TDC and help the mixture burn by stiring it up a bit.
There doesn't seem to be a verdict out on how much it helps hondas. I have heard of I think Import Builders porting the head to match bigger bores, purposely taking away from the quench area.
Old Feb 10, 2004 | 07:01 PM
grndcont's Avatar
i ran the inline pro gasket for awhile. it held up for about year @12 psi. totaly stock on the inside, they dont last forever that way though.
AngelTeg
Nov 30, 2005 08:20 AM
deacs
Oct 4, 2002 07:56 AM
Charles B.
Oct 29, 2001 09:26 AM
The Punisher
Aug 16, 2001 10:00 PM
