What does your boost guage read at idle?
Old Nov 25, 2002 | 06:11 AM
fsp31's Avatar
Default What does your boost guage read at idle?
I'm trying to see if my boost guage (just installed) is reading accurately. At idle I'm sitting right around -15 to -16 psi. Does that sound right? Also, when things are quiet I can hear a very faint hissing noise from the guage (obviously there's a vacuum line...). Is that typical? Does the guage itself bleed off a tiny amount of vacuum (or boost) all the time? Thanks.
Old Nov 25, 2002 | 06:13 AM
Doodoo's Avatar
Default Re: What does your boost guage read at idle? (fsp31)
I think the average is about 18-20inHG. The gauge does not leak at all. One hose from the IM to the guage.
I run about 25inHG on a good day.
Old Nov 25, 2002 | 07:46 AM
CovertFI's Avatar
Default Re: What does your boost guage read at idle? (Doodoo)
what have you doen to your car? if you have wild cams it could cause this or bad blow by. or you could just have a hole in the line
Old Nov 25, 2002 | 07:50 AM
HybridKOOP's Avatar
Default Re: What does your boost guage read at idle? (CovertFI)
18hg/in
Old Nov 25, 2002 | 07:57 AM
B00STeD's Avatar
Default Re: What does your boost guage read at idle? (HybridKOOP)
19-23 hg/in
Old Nov 25, 2002 | 08:04 AM
b16ahybrid's Avatar
Default Re: What does your boost guage read at idle? (B00STeD)
18 - 20 in/hg
Old Nov 25, 2002 | 08:13 AM
TurboDX's Avatar
Default Re: What does your boost guage read at idle? (b16ahybrid)
vaccum is @ 20....
Old Nov 25, 2002 | 08:33 AM
fsp31's Avatar
Default Re: What does your boost guage read at idle? (TurboDX)
Sounds like I have a leak in the line running to the guage. Internals on the motor are stock. (sigh) Guess that's the price I pay for having a "heavy handed" friend help me out. Hopefully it's just leaking right at the back of the guage. Thanks for the replies!!!
Old Nov 25, 2002 | 10:21 AM
Teg4e's Avatar
The harder I run my car, the stronger the vaccuum is. At cold start-up, it idles at 18, but warmed up it's around 20. After running the car hard, the vaccuum goes as high as 23 at idle. Anyone else find the same thing?
Old Nov 25, 2002 | 10:33 AM
hybrid901's Avatar
Default Re: What does your boost guage read at idle? (Teg4e)
19-20 even with 1 cylinder leaking 70%
Old Nov 25, 2002 | 11:06 AM
CovertFI's Avatar
the warmer your car is the better they seal. also when you run your car hard you are most likely not running the ac so your vacuume will be higher.
Old Nov 26, 2002 | 07:18 AM
fsp31's Avatar
Just because I know everyone has been worrying about this...
I found the leak at the back of my guage and fixed it with some tephlon tape (shoulda been on there to begin with). Now my idle sits right at -20 and off-throttle takes it to about -23. Thanks for the help y'all!!!
h9civic3
Jul 2, 2015 07:04 AM
vtak2nr
Aug 27, 2009 03:59 AM
ZCcivic91
Sep 9, 2007 07:26 PM
ericstambaugh07
Jul 3, 2007 07:59 PM
boosted.CRX
Dec 12, 2006 06:13 PM
