What does this have to do with forced induction?
Old Sep 16, 2004 | 11:30 PM
  #26
MidShipCivic's Avatar
Hows the throttle response?
Can I see a Dyno tony?
I was strongly considering doing this for my setup.
Old Sep 16, 2004 | 11:39 PM
  #27
racinskittle's Avatar
Default Re: (MidShipCivic)
LOL!! Good **** right there. That is by far the best engine bay i've ever seen. Great sleeper man!!!! That's sweet. In the pitch black, no one could tell.
Old Sep 16, 2004 | 11:45 PM
  #28
FredoSP's Avatar
Default Re: What does this have to do with forced induction? (Tony the Tiger)
even the MSD box is painted black, lol
Old Sep 17, 2004 | 12:48 AM
  #29
kKdARIAN's Avatar
Vice President/CEO
Default Re: What does this have to do with forced induction? (FredoSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP &raquo;</TD></TR><TR><TD CLASS="quote">even the MSD box is painted black, lol</TD></TR></TABLE>
haha, i just noticed that too... sheesh
Old Sep 17, 2004 | 01:24 AM
  #30
sporkcrx's Avatar
Default Re: What does this have to do with forced induction? (kKdARIAN)
That's awesome
Old Sep 17, 2004 | 01:27 AM
  #31
leed's Avatar
Default Re: What does this have to do with forced induction? (sporkcrx)
Very sexy!!
Alot of time went into that. Big on a very custom setup.
Whats the RPM switch for?
Old Sep 17, 2004 | 01:42 AM
  #32
plusONE jboy's Avatar
pretty stealthy.
Old Sep 17, 2004 | 01:48 AM
  #33
Tony the Tiger's Avatar
Default Re:
Thanks for the great comments from some of you
Anyway, the main reason of "hiding" the parts was to create a more stealthy appearance. Most of us here are turbo honda guys, so obviously, you would know what to look for.
Things hidden out of plain sight are:
- manifold
- turbo
- BOV
- FMIC
Things that create some confusion are:
- fake air box (used to be a filter when I was NA)
- stock heatshield
You'd be surprised how many "Honda" guys got fooled by my engine bay already. The non-import guys still cannot believe my Integra was stock with only an AEM CAI
To point out some things... The braided line at the manifold is an EGT probe and not an oil feed line.
The "thing" behind the heatshield is not the turbine housing. It's the downpipe. The turbine housing is tiny and it is completely enclosed under the heatshield.
I am still an all out all motor guy at heart, but my 2.0L NA motor took a crap from all the abuse and I needed something different.
So the goal was to build a turbo setup with the widest powerband possible and instant engine/throttle response. None of the 400+ WHP with turbos larger than their faces. Every turbo car I have been inside suffers from lag, but most guys don't detect it because they are either going from stock to boosted, or just more boost and a larger turbo. But from an owner of an all decked out all motor setup like myself, even a little turbo lag seems like forever.
EDIT: My turbo setup as follow (updated on Jan.31, 2005):
B18C1 with 11.5:1 CR (10.1:1 CR Arias Pistons with extesively milled head)
Eagle Rods
Canadian Cylinder Heads Technology Ported B18C1 head
2001 USDM ITR cams
Garrett GT28RS turbo with 0.86 A/R tubine housing
HKS manifold (internal WG)
3" Downpipe and exhaust
26" x 6" x 2.5" FMIC, with black heat coating
2.25" charge pipes, 2.5" near throttlebody(s)
HKS SSQV mounted near front fender
Jenvey 51mm ITB's with custom middle-entry plenum manifold
RC 550 cc/min, fuel pressure at 60 psi
AEM EMS
9200 RPM redline
Running 11-12 psi
Custom Alchy/Water Injection (not pictured)
Let's just say my car drives close to my old NA setup, but with a lot more power and torque everywhere else... Low-end response is not as great, but the midrange power really makes up for it
Modified by Tony the Tiger at 11:49 PM 1/31/2005
Modified by Tony the Tiger at 11:50 PM 1/31/2005
Old Sep 17, 2004 | 01:52 AM
  #34
Intercooler pic:
The coating is an actual heat emission coating... commonly used in condensers and factory radiators.
Pic of turbo with heatshielf removed:
(updated pic as of Jan.31, 2005)
Modified by Tony the Tiger at 11:51 PM 1/31/2005
Old Sep 17, 2004 | 02:05 AM
  #35
Wow very nice, Tony can we see a video of that throttle response and a dyno sheet.
I would really like to see the curve's OR BAN haha j/k.
Old Sep 17, 2004 | 02:08 AM
  #36
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">Wow very nice, Tony can we see a video of that throttle response and a dyno sheet.
Most likely, videos will come sooner the dyno... Gotta wait for a couple of buddies to finish their buildup so we can all hit the dyno one day at the same time
Old Sep 17, 2004 | 02:09 AM
  #37
leed's Avatar
Default Re: (Tony the Tiger)
11.5 C/R on a BB GT28. Dam, must be a VERY nice car to drive.
Curious as to how much timing you run on the top end with 10psi?
Oh, one more thing. Do you get a good enough range of MAP reading at part throttle for a solid part throttle tune with that vacuum log? Having helped a friend tune ITBs while still using the MAP was very difficult as it only took about 25-30% throttle opening to reach an indicated 0" vacuum, and the end of the maps.
Old Sep 17, 2004 | 02:13 AM
  #38
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: (leed)
wow that is the ultimate sleeper!! What happend to the IC I sold you??
Old Sep 17, 2004 | 04:21 AM
  #39
White Smoke's Avatar
i my honda
Global Mod
Default Re: What does this have to do with forced induction? (DC2EATER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2EATER &raquo;</TD></TR><TR><TD CLASS="quote">maybe stupid question, but if boosted why is the valve cover breather connected to the upper charge pipe?</TD></TR></TABLE>
Defiantly NOT a stupid question!!
Why do you have it like that?? Not a good thing
Old Sep 17, 2004 | 04:39 AM
  #40
importtuner's Avatar
Default Re: What does this have to do with forced induction? (si2die4)
Damn that's freakin crazy!! So how much power you think you're putting?? Most importantly, how does this car compare to your previous one???
-Justin
Old Sep 17, 2004 | 05:18 AM
  #41
Ri5e's Avatar
LOL ... love the "AEM" Sticker.
Old Sep 17, 2004 | 05:38 AM
  #42
Dr Pooface's Avatar
My guess: it's fake.
Old Sep 17, 2004 | 06:07 AM
  #43
Boostage's Avatar
Old Sep 17, 2004 | 06:10 AM
  #44
USDM 4G VTEC's Avatar
looks good
u can see the EGT line
but the vacum manifold gives it away
the wastegate can be seen
the VTEC controller (RPM activated switch, ghetto but works) is funny
the valve cover seems to be hooked to the valve cover... but hopefully is not.,.. i am saying theres a catch can somewhere since theres another line on the front of valvecover..and it was just routed to mislead.. as u can see the line on the intake is smaller
ITB's are sweet btw
Old Sep 17, 2004 | 06:36 AM
  #45
Boostage's Avatar
Default Re: (USDM 4G VTEC)
is there any benefit to ITB'sona FI setup?
Old Sep 17, 2004 | 06:45 AM
  #46
XSIintegra's Avatar
Default Re: (Boostage)
I love anything hidden like this. Where did you get the intercooler painted? I have wanted to do that for my DA but I haven't found anyone in town or a paint I can shoot it with. Again...Very Nioce setup
Old Sep 17, 2004 | 07:02 AM
  #47
Charlie Moua's Avatar
Default Re: What does this have to do with forced induction? (DIRep972)
dood you could of done a better job than that. hehe
I actually though about using stock intake arm/box. and using the air BOX to place a dsm bov in there but for the charge piping simply just use some big *** radiator hose.
I see that your runing a t28. I've always wonder what the power band would look like. I'ma huge fan of small turbos on FI honda (see links in sig) I'm using an apexi kit bb turbo with hks manifold.
man i reallly would kill to see your midrange power.
Old Sep 17, 2004 | 07:28 AM
  #48
integranator's Avatar
Default Re: What does this have to do with forced induction? (Charlie Moua)
that intake manifold looks rediculous!! Is the port underneath it?
Old Sep 17, 2004 | 07:36 AM
  #49
done's Avatar
Default Re: Re: (Tony the Tiger)
man i miss all your cool videos tony!!!
Old Sep 17, 2004 | 07:40 AM
  #50
EJ1 wilcox's Avatar
Default Re: What does this have to do with forced induction? (integranator)
Nicely done!
This is the first time I've seen someone go to such lengths to hide their setup!
