what do these plugs look like??
Old May 24, 2004 | 07:29 PM
TurboBumblBee's Avatar
Default what do these plugs look like??
while my downpipe is off at the shop getting repaired, i decided to change the oil and check the plugs on the car.. im putting 10w-30 synthetic oil in this time as i read was better then 5w-30 for the engine w/ the turbo and all the heat it creates.
someone take a look at these plugs and tell me what you think of them.. they had a brownish color to them almost and some white.. i know white is lean but it cant be running that lean w/ the 440s and the vafc hack set at -30%..
i was driving the car for about 2 hours the day the downpipe broke the rest, it was back firing and not running the great w/ no back pressure.. could driving that little bit done that much to the plugs? even if these do look good i still ordered a set of ngk bkr7e plugs.. i should gap these plugs to about .028-.035 correct??? i know i need to play w/ the gap to get the best out of them..
plus are in order of 1-2-3-4 starting at the left of the picture
cynlinders 1 and 4 look a little lean dont they??
thanks everyone
Old May 24, 2004 | 08:28 PM
Vtec92Civic's Avatar
Default Re: what do these plugs look like?? (Boostfedb18c1)
plugs 2 and 3 are def rich . . . plugs 1 & 4 are def. leaner then 2 & 3 but the tanish color shows that they are running stoich 14:1
I personally always wondered how to fix things if 1 or 2 cylinders is running richer or leaner then the other. it could be that those 2 injectors (1 & 4) are just a little dirty? Run some injectors cleaner through them, and if you have the cash you can always have them sent away to get flow tested and cleaned.
Old May 25, 2004 | 04:20 AM
Default Re: what do these plugs look like?? (Vtec92Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtec92Civic &raquo;</TD></TR><TR><TD CLASS="quote">plugs 2 and 3 are def rich . . . plugs 1 & 4 are def. leaner then 2 & 3 but the tanish color shows that they are running stoich 14:1
I personally always wondered how to fix things if 1 or 2 cylinders is running richer or leaner then the other. it could be that those 2 injectors (1 & 4) are just a little dirty? Run some injectors cleaner through them, and if you have the cash you can always have them sent away to get flow tested and cleaned. </TD></TR></TABLE>
thanks.. isnt stoich ok for them?? and ill get some injector cleaner in the tank today.. the injectors are new from RC and they have less then 5000k miles on them.. i also randomly get CEL 43 which is fuel supply system, and when i get that sometimes the fuel pump doesnt prime correctly or turn on.. i can keep trying or hit the fuel pump and move the ecu and it starts better sometimes.. im almost positive its a wire that has come loose somewhere, but im uncertain where to look.
*edit.. and when the CEL 43 is on i will notice a little bit of smoke from under the hood, ill turn the car off, restart it and it is fine afterwards ( i think this has to do w/ the plugs being bad) any ideas on what to do to fix it? ive been told to replace the o2 sensor but i think its wiring related
Old May 25, 2004 | 04:25 AM
Naterror's Avatar
2 and 3 are running a little rich, although without reading a wideband its hard to tell how rich. You need to get a wideband on it, try playing with the gap a little on 2 and 3. You may find that you'll need to take fuel out or even have to add fuel, but from looking at the plugs you need to get a wideband on it.
For a daily driven car it should be around 12:1
Old May 25, 2004 | 04:44 AM
Default Re: (Naterror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Naterror &raquo;</TD></TR><TR><TD CLASS="quote">2 and 3 are running a little rich, although without reading a wideband its hard to tell how rich. You need to get a wideband on it, try playing with the gap a little on 2 and 3. You may find that you'll need to take fuel out or even have to add fuel, but from looking at the plugs you need to get a wideband on it.
For a daily driven car it should be around 12:1</TD></TR></TABLE>
i would rather have it running rich then lean so i dont detinate.. the plugs were gapped at .28 or .028 whatever it is.. lol
would driving the car w/ the downpipe cracked very badly like it was, causing the car to hesitate, and backfire, cause 1 and 4 to go bad like that???
Old May 25, 2004 | 04:53 AM
SOHC_MShue's Avatar
Default Re: (Boostfedb18c1)
i know my car ran kinda shitty on open downpipe. It also caused wild boost spikes that caused me to blow my headgasket
Old May 25, 2004 | 08:31 AM
Default Re: (SOHC_MShue)
don't want to jinz myself *knocks on wood* I use to get cel 43 all the time, and could never figure out what it was, but it finally just went awa after the many times that I tok the motor a part etc . . . . Having the plugs run stoich is so so I guess. People say for boosted cars that is way to lean, but if your car was backfiring and what not that might be the cause for those 2 plugs looking the way that they do. It could also maybe be those 2 spark plug wires are going bad, or maybe even a timing issue.
How does the car feel throughout boost? Does it hesitate, or cutout or anything, or is it 100% smooth entering boost?
Old May 25, 2004 | 10:15 AM
Default Re: (Vtec92Civic)
How does the car feel throughout boost? Does it hesitate, or cutout or anything, or is it 100% smooth entering boost?</TD></TR></TABLE>
i did have a kenji spec itr chipped p28 ecu running the car for a couple weeks, that came out of an old car that i sold that i barrowed from the girl i sold it to.. that ecu ran really rich in my old car and i could tell that the current car seemed to run better than it did using a stock p72 ecu.. im using a stock obd1 p72 ecu on a 2.0 b18c1 motor, stock head, and i also have a skunk2 IM so im thinking maybe a p30 ecu might be worth a shot cause i dont have the correct IM for the ecu i currently have..
it was smoother going into boost w/ the chipped p28 then it is w/ the p72.. i seems to hesistate at about 4k rpms, but once its past that it flies to redline after vtec enguages.. what kind of adjustments should i do to the vafc using the stock p72 for smoother boost transistions? or what else can do to acheive this? thanks
ironcheftony
Jun 11, 2007 08:55 AM
turbo_ef9
Aug 30, 2005 07:20 PM
stumpyf4
Jul 8, 2004 06:29 PM
sporkcrx
Jul 3, 2004 07:59 PM
ITR77
May 31, 2003 05:31 PM
