What to do with JRSC
Old Dec 2, 2002 | 07:08 PM
CIVILGSR's Avatar
Default What to do with JRSC
i have a jrsc it needs to be rebuilt which i plan on doing. i have a gsr with a full skunk 2 head, skunk 2 stage 2 cams, JE pistons, and eagle rods. i am thinking of putting the jrsc on the gsr, but I have questions on what needs to be changed like cams and pistons or should the pistons be ok. i was also thinking on changing my hondata to the AEM system would that be ok with the SC. anyone have any ballpark figure in possible HP and Trq. Thanks for all the help.
Old Dec 2, 2002 | 07:12 PM
LOwrestling2001's Avatar
Default Re: What to do with JRSC (CIVILGSR)
um...u need to do a lot more reading up. U won't wanna use skunk2 stg 2 cams with FI. Drop compression or keep it the same, up to u. hondata is fine.
Old Dec 2, 2002 | 07:35 PM
CIVILGSR's Avatar
Default Re: What to do with JRSC (LOwrestling2001)
I know that I was looking for suggestions on what cams to run and I would need a hondata 2b. what is your setup on ur gsr????
Old Dec 2, 2002 | 07:38 PM
Turismo's Avatar
There are no known gains and many losses when using cams other then stock on a JRSC GSR. I would leave it and compression alone. Your not going to be able to boost high enough to need to and you will lose power. If your running Hondata w/ 440 injectors you will be fine. Thats my setup with a 8psi pulley and I dyno'd at 219 to the wheels still real rich and before I got a real intake exhaust and did some tweaking. I've seen some over at Hostboard.com with 250-260whp JRSC GSR.
97_BB6
Mar 12, 2007 10:35 PM
BLK99VTECR
Dec 16, 2003 12:47 PM
ID_ten_T
Jun 15, 2003 11:11 PM
CIVILGSR
Nov 18, 2002 07:47 PM
a z n t a k
Feb 13, 2002 04:22 PM
