what to do with b16 block???
Old Jun 18, 2003 | 12:31 PM
granada_sun's Avatar
Default what to do with b16 block???
Alright this is a pretty dumb noob question, but i need some help so please bare with me.
I've got a 2nd gen b16 block to mess around with, and want to turbo it, would like to get into the high 300+hp mark with del sol.
I called up machine shop they said they could bore it out to 84mm for $120. I asked the guy about resleeving, he said there was no need for that or knife-edging the crank unless I was going for hardcore track racing. I mean it's going to the track, but also my daily driver.
What would you guys do??? Thanks for the input, PEACE
Old Jun 18, 2003 | 01:19 PM
EVOLMTR's Avatar
Default Re: what to do with b16 block??? (granada_sun)
You don't want to bore you block to 84 mm on stock sleeves and boost because your making the stock sleeves even thinner and more likely to crack at first sign of denotation.
Old Jun 18, 2003 | 01:27 PM
TeStUdO's Avatar
anything over 81.5mm on stock sleeves will crack easily. if you want 84mm sleeve the block
Old Jun 18, 2003 | 01:31 PM
alpha's Avatar
I would say that machine shop doesn't have any experience with Honda blocks.
Old Jun 18, 2003 | 01:38 PM
They probably don't I mean most of the cars up here that are modded for racing are domestics, we all know the differences with those and imports.
So the best best would be to ship it out with reputable place huh?
thanks again futha help....
Old Jun 18, 2003 | 02:04 PM
alpha's Avatar
Default Re: (granada_sun)
Is there a crack in the sleeves or something? With good tuning (Honda, FAST, AEM's EMS) you will not need to resleeve. There were two reasons I resleeved. The B16a block I got for FREE had a crack in one of the sleeves and I am shooting for 475whp. With a good piston/rod combo you will be fine.
Old Jun 18, 2003 | 02:59 PM
nah the sleeves are fine, I've been reading all over that in order to bore out a b16 and keep it from cracking is to resleeve it.
I mean I want to bore the engine while its apart and out of the car, just got to know what works and what won't.
Old Jun 18, 2003 | 04:37 PM
and i want a ridiculous amount of horsepower so i can toast a vette in town......
Old Jun 18, 2003 | 05:22 PM
Hispeed's Avatar
300's are no problem.. leave the block stock and just spend the money on upgrading your valve train to allow you rev a bit higher safely. And secondly spend the money on a standalone & injectors. That should easily net you mid 300's with a t3/t4e turbo or bigger. I was very happy with my stock b16.. so much so it's my back up motor and it's stock! It netted high 11's w/ 330hp and was a boat load of fun on the streets. A stock corvette would be childs play If you want to push more than that slap a block guard in and place some forged pistons and rods in.
Old Jun 18, 2003 | 05:36 PM
standalone or hondata?
i kind of like AEM because the tuning is wicked, well, tuneable.....
but then again hondata isnt too bad either I guess.....
Guess VAFC wouldnt be needed with standalone huh?
Old Jun 19, 2003 | 07:44 AM
alpha's Avatar
Yeah Hondata isn't too bad Find a good tuner in your area and see what he/she recommends.
Old Jun 19, 2003 | 07:59 AM
raene's Avatar
Default Re: what to do with b16 block??? (GSRev)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRev &raquo;</TD></TR><TR><TD CLASS="quote">300's are no problem.. leave the block stock and just spend the money on upgrading your valve train to allow you rev a bit higher safely. And secondly spend the money on a standalone & injectors. That should easily net you mid 300's with a t3/t4e turbo or bigger. I was very happy with my stock b16.. so much so it's my back up motor and it's stock! It netted high 11's w/ 330hp and was a boat load of fun on the streets. A stock corvette would be childs play If you want to push more than that slap a block guard in and place some forged pistons and rods in. </TD></TR></TABLE>
You're making me rethink my desire to swap my shortblock for a B18C
Old Jun 19, 2003 | 09:49 AM
hey any you guys want to buy a del slow?
Old Jun 19, 2003 | 03:23 PM
Hispeed's Avatar
Default Re: what to do with b16 block??? (raene)
i would suggest a b16 anyway as a starter turbo motor. b18c are expensive if something goes wrong.
Old Jun 19, 2003 | 03:28 PM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRev &raquo;</TD></TR><TR><TD CLASS="quote">i would suggest a b16 anyway as a starter turbo motor. b18c are expensive if something goes wrong. </TD></TR></TABLE>
they are only more initially expensive, after that if you blow it it will cost the same as a b16 to repair unless you buy a new shortblock. that extra stroke on the b18c gets really noticable when you boost it
Old Jun 19, 2003 | 03:33 PM
raene's Avatar
That is very true and a very good point.
But switching a B16A to a B18C - could I just boost the B16A first, then swap blocks down the road? Will the turbo manifold clear the oilpan?
I want to do it right the 1st time... but I know I'm going to make some mistakes, especially on my 1st turbo engine
jceltalentoso
Jan 15, 2012 10:00 PM
walo
Nov 14, 2011 01:15 PM
88crxhfb16
May 15, 2005 02:08 AM
RICE POLICE SIP
Mar 26, 2003 07:41 PM
BLKCRX
Apr 5, 2002 09:18 AM
