WHat is the diffrence between a T3/60-1 and a T3/T67
Old Nov 21, 2004 | 10:32 AM
B18c1turboedEK's Avatar
Default WHat is the diffrence between a T3/60-1 and a T3/T67
I have been loonig at these 2 turbos right now im running the T3/60-1 and have been thinking about buying the T3/T67 but after reading a little theres really not much ofa diffrence is there??
T3/T67 .63 or .82 A/R Turbo
Specifications:
Turbine
4 bolt T3 turbine housing.
76 trim stage V wheel.
0.63 AR or 0.82 AR.
Optional HPC coated housing.
Compressor
63 trim 67mm T04R wheel.
Max flow rate of 75lb/min.
T04S housing.
0.70 AR.
Optional polished housing.
Also comes standard with 360 degree thrust bearing.
Garret t3/60-1
COMPRESSOR SPECS:T04S housing
flow: 61 lbs/min 781cfm
.70 A/R housing
60 TRIM wheel
TURBINE SPECS:T3
.63 A/R housing
HIGH FLOW 76 TRIM stg 3 wheel
oil lubricated centersection.
for use with external wastegate.
due to large compressor flow, internal wasgate option not available.
COMES STANDARD WITH 360 DEGREE THRUST BEARING!!!
Old Nov 21, 2004 | 01:47 PM
Default Re: WHat is the diffrence between a T3/60-1 and a T3/T67 (B18c1turboedEg)
Old Nov 21, 2004 | 01:54 PM
80884's Avatar
I think you answered your own question, just reread what you posted...
T3/T67 = Max flow rate of 75lb/min.
T3/60-1 = flow: 61 lbs/min 781cfm
T3/T67 flows 14lbs/min more than the 60-1 for one thing.
Also what size compressor wheel is on the 60-1? probably isn't 67mm.
Old Nov 21, 2004 | 04:27 PM
Default Re: WHat is the diffrence between a T3/60-1 and a T3/T67 (80884)
Ill be honest with you ui never knew how to read the compressor and so forth thats why i was asking, thanks alot man
Old Nov 21, 2004 | 05:37 PM
s2kdre's Avatar
i didnt think 60-1 was capable of doing 700+hp like the t67.
Old Nov 21, 2004 | 09:23 PM
M.A.R.C.'s Avatar
Default Re: WHat is the diffrence between a T3/60-1 and a T3/T67 (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">i didnt think 60-1 was capable of doing 700+hp like the t67.</TD></TR></TABLE>
i don't think it is. i think it's like 500-600whp range for the 60-1
Old Nov 22, 2004 | 04:55 AM
Default Re: WHat is the diffrence between a T3/60-1 and a T3/T67 (M.A.R.C.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M.A.R.C. &raquo;</TD></TR><TR><TD CLASS="quote">
i don't think it is. i think it's like 500-600whp range for the 60-1</TD></TR></TABLE>
I would be happy with 600HP...
Old Nov 22, 2004 | 05:25 PM
Full-Race Geoff's Avatar
the 60-1 turbo uses a stage 3 turbine wheel and a compressor wheel that is capable of making up to 560 whp. It is an excellent turbo and MANY people have had great luck with it.
the t3/t67 is a much larger turbo, and it does lag significantly more, about 1000 rpm later to be exact. It uses the same exact center section as the 60-1, but has different turbine and compressor wheels. The off the shelf t3/t67 uses a stage 5 T3 turbine wheel with the t67 compressor wheel, and the high output t3/t67 uses a p trim T4 turbine wheel. The high output t3/t67 is techincally a t4 turbo, but in a t3 frame.
Old Nov 22, 2004 | 06:12 PM
B16A1-EF9's Avatar
Default Re: WHat is the diffrence between a T3/60-1 and a T3/T67 (jerseykid609)
I've got Cheapturbo's T3/T04R. I've got the .82 a/r stage 3 wheel on the turbine side.
They've got a fully built GSR run 27psi making 580+
Hopefully it works for me just as well...
Old Nov 22, 2004 | 07:00 PM
Default Re: WHat is the diffrence between a T3/60-1 and a T3/T67 (Full-Race Geoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Geoff &raquo;</TD></TR><TR><TD CLASS="quote">the 60-1 turbo uses a stage 3 turbine wheel and a compressor wheel that is capable of making up to 560 whp. It is an excellent turbo and MANY people have had great luck with it.
the t3/t67 is a much larger turbo, and it does lag significantly more, about 1000 rpm later to be exact. It uses the same exact center section as the 60-1, but has different turbine and compressor wheels. The off the shelf t3/t67 uses a stage 5 T3 turbine wheel with the t67 compressor wheel, and the high output t3/t67 uses a p trim T4 turbine wheel. The high output t3/t67 is techincally a t4 turbo, but in a t3 frame.</TD></TR></TABLE>
Old Nov 23, 2004 | 09:58 PM
91hondaman's Avatar
so geoff u mentioned the 60-1 is cabable of makin 560hp so how much your off the shelf t3/t67 is capable of makin
Old Nov 24, 2004 | 11:30 AM
Default Re: WHat is the diffrence between a T3/60-1 and a T3/T67 (91hondaman)
there are 3 kinds of off-the-shelf t3/t67
1) t3/t67 .63 a/r stage 5 -- 620 whp
2) t3/t67 .82 a/r stage 5 -- 640 whp
3) t3/t67 .82 a/r p trim -- 700 whp
Old Nov 24, 2004 | 11:37 AM
M.A.R.C.'s Avatar
no stage 3 wheel option?
Old Nov 24, 2004 | 11:43 AM
wantboost's Avatar
Who is Mr Robot?
anyone have any t3/t67 vids?
Old Nov 24, 2004 | 11:44 AM
PM-Performance's Avatar
the full race turbo also has more technology in it . Geoff has the shafts polished up so they spin rediculously. Mine would spin a min or so after i shut the car off from an idle
Old Nov 24, 2004 | 10:52 PM
91hondaman's Avatar
thanks
Old Nov 24, 2004 | 10:56 PM
91hondaman's Avatar
Default Re: WHat is the diffrence between a T3/60-1 and a T3/T67 (itr206)
Hey bro which one of these t3/67's u had, that type r u had is sick and i see that the new owner has done 11.2 so close to tens these full race t3/67's are sick with the power and numbers to back them up
Cat'sturboteg
Jul 15, 2007 11:22 AM
mrx
Sep 3, 2005 11:27 AM
scooter
Jun 24, 2004 03:42 PM
TurboJesse
Mar 24, 2003 07:27 PM
B20bTurbo
Nov 22, 2002 03:39 PM
