what coolant do you guys use?
Old Sep 8, 2003 | 11:20 AM
DXturbo's Avatar
Default what coolant do you guys use?
just wondering what types of coolant are you guys using in your boosted machines?
Old Sep 8, 2003 | 11:46 AM
DXturbo's Avatar
Default Re: what coolant do you guys use? (DXturbo)
thanks to another honda-tech member (ee-chris) he mentioned something bout soft soap anyone know what hes talking bout? also, what does water wetter do for coolant?
Old Sep 8, 2003 | 11:50 AM
Hoosier Daddy's Avatar
I use the cheapest pre-mixed coolant
Old Sep 8, 2003 | 11:51 AM
LiLOtaku's Avatar
Default Re: what coolant do you guys use? (Boost Creep)
just get some regular prestone, do a 50/50 mix and add "Water Wetter" to it.
Old Sep 8, 2003 | 12:02 PM
Muad'Dib's Avatar
Corr Performance Pilot
NEO coolant on my car.
Old Sep 8, 2003 | 12:08 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (MouhadIb)
Genuine Honda mix.................Im picky
Modified by HybridcivicLS-T at 4:57 PM 9/8/2003
Old Sep 8, 2003 | 12:12 PM
BROOD's Avatar
Default Re: (HybridcivicLS-T)
I used oem Honda pre-mix coolant but have been using Shell Rotella ELC with good results. It is cheaper but still follows Honda's requirements that their cooling system was designed with. I would never run plain Eth-Glycol coolant in my engine.
The secs sheet on Shell ELC: low silicate formula
https://thegenesisnetwork.equi...C.pdf
Old Sep 8, 2003 | 12:13 PM
Foozball26's Avatar
Default Re: (SLPR)
prestone pre-mixed for me
Old Sep 8, 2003 | 12:18 PM
DXturbo's Avatar
Default Re: (Foozball26)
i used the honda stuff but damn its getting expensive...
anyone care to explain what water wetter is?
Old Sep 8, 2003 | 01:54 PM
R6Elmo's Avatar
Default Re: (DXturbo)
redine water wetter or royal purple's ice are similar in that you can run just water and add these items in to lube the water pump and other items. WIth distilled water and the above items, it suits fine for track use as you don't want glycerol based fluids leaking on the track (road course..not drag)
Old Sep 8, 2003 | 01:56 PM
espanol's Avatar
i use the redish/pinkish stuff from toyota..
Urugly
Oct 15, 2007 01:45 PM
benmasters
May 25, 2003 12:47 PM
TurBoXBirD16
11
Mar 20, 2003 01:55 PM
T_Rex
Nov 9, 2002 06:21 PM
TheIntegraGuy
Sep 24, 2002 09:42 PM
