What BORE?
Old Mar 19, 2002 | 10:59 AM
2K_TEG's Avatar
Default What BORE?
I will be sending my block (B18B) to Golden Eagle sometime this spring. What bore should I go with? Should I go all out and get the 84.5mm or is a smaller bore just as useful. I plan on boosting 15 - 20 psi. Daily Driven.
What are the advantages and disadvanges of each? Is there a "perfect bore"? TIA,
2K_TEG's Avatar
Default Re: What BORE? (2K_TEG)
Cool,
https://honda-tech.com/zerothread?id=144986
Old Mar 19, 2002 | 11:07 AM
ArizonaTurbo's Avatar
We are sending my buddy's block out and we decided to go with an 83mm piston only because we will have room to play with if we lose the motor. We will have a few more hones out of it! You might as well get your full money's worth out of it!
[Modified by APEXSER, 1:07 PM 3/19/2002]
Old Mar 19, 2002 | 02:47 PM
2K_TEG's Avatar
Default Re: What BORE? (APEXSER)
Good point. Anyone else? Thanks
Shootinfor6s
Mar 5, 2007 02:35 PM
Akiraboy
Dec 15, 2005 10:08 AM
Dorikamu
Mar 2, 2003 01:10 AM
Quik Chris
Dec 21, 2002 10:11 AM
