What boost pressure to make 400 whp on a T3/To4E .63 / 57 trim??
Anyone have any idea? I kinda suck at reading compressor maps. The motor is gonna be fully built staying at 81mm and running 9.5:1 compression.
Thanks guys......
I will have my Darton closed deck done in the next week or so---I will be sure to post some pics.
[Modified by 93LSivic, 7:55 PM 10/29/2002]
Thanks guys......
Re: What boost pressure to make 400 whp on a T3/To4E .63 / 57 trim?? (93LSivic)
Too many variables to determine this, what about cams stock? headwork? Intake manifold? It can be done, I made 370whp with 14psi but this is a B16A bored to 84.5mm 9.5:1 CR headwork, oversized valves, JG/Edelbrock manifold, my old set up did the same #sw but needed 21psi. New set up is a T3/60-1. I think you could easily make your goal with about 20psi, Earl and Mike aka ninesecrx had a dyno of a GSR motor with a T3/T04E 54 trim and it made 441whp and 367 ft-lb torque. This motor had a good amount of work done too.
Re: What boost pressure to make 400 whp on a T3/To4E .63 / 57 trim?? (DIRep972)
GSR or LS motor?
Some more details of the motor:
Stock sized Ferrea intake and exhaust valves. Stock valve seats.
Crower dual valve springs.
Stock LS cams.
Ported and polished head.
Venom sheetmetal intake....with custom oval-ish plenum
Stock throttle body---probably do a bored one later.
Hondata tuned
Fuel system is done....with the exception of the 550's that wont let me hit that 400 mark -- I know I will need 720's.
Exhaust is gonna be 3"...but i want 400 whp on open dp and race gas.
Smarter than you
GSR or LS motor?
Come on Chris you should know......LS of course.
Re: What boost pressure to make 400 whp on a T3/To4E .63 / 57 trim?? (W.ZeroB18C1T)
man....i still wonder whether i should switch to a GSR bottom end? (over straight b16)hrmmmmmmmm
earl
10-24-2001 06:09 PM
