What am I missing?
Old Jun 9, 2004 | 01:09 PM
Hatchbizzack's Avatar
Default What am I missing?
Here's is what I have so far for my turbo kit. I am still missing some bits and pieces, so here's the list:
GReddy Turbo Manifold
Mitsubishi 16g turbocharger
Yonaka Motorsports 21x9x3 Front Mount Intercooler
Blitz DD Universal Blow Off Valve
Blitz Aluminum mounting flange
Jackson Racing FMU
Oil feed line kit
Oil return line kit
Here's what I know I'm missing:
Intercooler piping (in the process of getting)
Downpipe (working out a deal on one also)
Boost Controller (Turbo XS Dual Stage coming soon)
Some type of tuning device.
Couplers and clamps for all the piping
Is there anything that I'm missing? I want to be sure that I have everything before I begin the install. Let me know if there is anything I'm missing. Any help would be greatly appreciated.
Old Jun 9, 2004 | 01:16 PM
Sam1am26's Avatar
Default Re: What am I missing? (Hatchbizzack)
How about some larger fuel injectors and a walbro fuel pump...
Old Jun 9, 2004 | 01:17 PM
EJ1 wilcox's Avatar
Do you have all the gaskets you need? I just spent $50 on all the gaskets I need
Also vacume(sp?) lines and or vacume manifold.
Also, gauges? You might have just not included them in the list because they are not really part of the kit...but they are important too!
That's all I can think of for now
Old Jun 9, 2004 | 01:23 PM
Default Re: What am I missing? (koreanwilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koreanwilcox &raquo;</TD></TR><TR><TD CLASS="quote">Do you have all the gaskets you need? I just spent $50 on all the gaskets I need
That's all I can think of for now </TD></TR></TABLE>
Yeah,I actually just forgot to put the gauges are part of the list, but I knew that I needed to get them. Where could I find the vacuum lines and gaskets at? No one local has anything for turbo'd cars.
Thanks for the help thus far guys.
Old Jun 9, 2004 | 01:28 PM
EJ1 wilcox's Avatar
As far as gaskets go...
It depends on which ones you need, I bought mine from both
http://www.atpturbo.com/
and
http://www.hondaautomotiveparts.com/home.htm
I bought a new header gasket, oil pan gasket, gasket from mani to adapter plate, adapter plate to turbo, and turbo to downpipe...
I know some people don't use all these gaskets but I really hate exhaust leaks!
You can get vacume manifolds from a few different companies, they aren't that expensive. You don't even really need one but it will keep things cleaner and your components (BOV, wastegate etc.) will work a lot more efficiently.
Old Jun 9, 2004 | 02:06 PM
94gsr4dr's Avatar
Fuel and some type of EMS
Old Jun 9, 2004 | 02:10 PM
Default Re: (94gsr4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsr4dr &raquo;</TD></TR><TR><TD CLASS="quote">Fuel and some type of EMS</TD></TR></TABLE>
I only intend to run 10 psi at most until I get the motor built, so what size injectors and fuel pump would be right for me?
b18sihatch
Jun 8, 2006 03:03 PM
99whitegsr
Feb 28, 2005 06:28 PM
roydogg
Nov 21, 2002 10:03 PM
Tr0LL
Aug 30, 2001 05:51 PM
Tr0LL
Jun 25, 2001 06:08 AM
