went to the dyno yesterday......
Old Apr 6, 2005 | 05:14 AM
TurboLude97's Avatar
Default went to the dyno yesterday......
Went to the dyno yesterday to get tuned and I found out that my 3 BAR map sensor is really a 2 BAR... Kinda pissed about that... So i didnt get to run as much boost as i hoped. I ended up making 255 hp and 195 ft lbs @!8 psi. I also had some problems with the nitrous control on the hondata... everything is wired correctly but when I made a run the first time it didnt come on (and the conditions were met) but after that I rechecked the wiring and now it comes on as soon as the ignition is turned on, it doesnt matter if it is armed or not.. any ideas on why it would be doing this??
Old Apr 6, 2005 | 05:47 AM
Benjithx's Avatar
Default Re: went to the dyno yesterday...... (TurboLude97)
shouldn't you be able to boost to 28 psi on a two bar. 1 bar=14psi?
Old Apr 6, 2005 | 05:55 AM
Default Re: went to the dyno yesterday...... (Benjithx)
no.. 1 bar = 0 psi... 2 bar is 15.. cuz you have to account for the 14.7 for atmospheric pressure.. thats 1 bar.
dornon13's Avatar
stock is like 1.75 isnt it?
Old Apr 6, 2005 | 06:00 AM
Default Re: went to the dyno yesterday...... (dornon13)
i think its somehting like that cuz you can run 11 psi on it
Old Apr 6, 2005 | 06:15 AM
YiNYaNg's Avatar
1bar=11psi
Old Apr 6, 2005 | 06:16 AM
93turbo16's Avatar
yea, no point in getting a 2 bar. 2.5 bar or 3 bar are the only useful ones.
Old May 20, 2005 | 12:39 PM
DigitalFusion's Avatar
Default Re: went to the dyno yesterday...... (H-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H-T &raquo;</TD></TR><TR><TD CLASS="quote">1bar=11psi</TD></TR></TABLE>
ummm... no. 1 bar=14.7
Old May 20, 2005 | 02:37 PM
Muckman's Avatar
Moderator in Chief
Default Re: went to the dyno yesterday...... (DigitalFusion)
he means a 1 bar MAP sensor.
HPfreak
Engine Management and Tuning
13
Mar 14, 2012 12:41 PM
CarAudioPro
Dec 31, 2005 11:10 AM
tallblondkid
Feb 17, 2005 10:20 AM
Ri5e
Jun 4, 2002 09:20 PM
LS-T
Dec 13, 2001 06:32 AM
