Weird Stalling problem, Need help
Old Sep 16, 2009 | 03:24 PM
1baddcivicsi's Avatar
Default Weird Stalling problem, Need help
My car has does NOT like to stay running. My IACV was leaking coolant a few days ago, bought an OEM IACV from Honda for $190. From a cold start, it starts right up & ides perfect, then when i rev it up past 4,000 RPM, then it falls past idle & stalls. After its good & warm, it starts up but drops below idle & stalls. Then after i got on it, it stalled going 45-mph, had to re-start it & keep my foot on the gas. WTF?
Should i look for something in my map? or what should i do?
Old Sep 16, 2009 | 04:29 PM
boostB4beauty's Avatar
Default Re: Weird Stalling problem, Need help
Does it always start right up after stalling, with no problems?
If it does start up fine, then i would suggest something with your MAP setup, as mine was doing a similar thing. I was running a VTEC-AFC for monitoring , and it was giving false readings, causing it to stall. Fixed the problem and haven't had any trouble yet!
Good Luck!
Old Sep 16, 2009 | 05:15 PM
yeah, it starts right up, but i have to keep my foot on the gas at all times to prevent stalling.
Old Sep 18, 2009 | 07:53 PM
So...... i need to check my GM 3-Bar Map sensor? or my AEM MAP?
Any other ideas?
Old Sep 18, 2009 | 09:01 PM
imationdawg's Avatar
try replacing the coil
Old Sep 19, 2009 | 08:09 AM
Distributor & starter are both NEW
adam00integra
Jan 2, 2012 10:03 PM
99ek4Dr
10
Mar 2, 2011 06:22 PM
ef9itb
Engine Management and Tuning
Jun 30, 2010 12:27 PM
happyabortion
17
Dec 15, 2008 09:33 AM
89 CRX SI
Apr 18, 2003 08:54 AM
