weird idle stuff
Old Dec 14, 2005 | 02:11 PM
nekoabandoned's Avatar
Default weird idle stuff
ok turbo spools,runs ok but a little slugish.when i idle after a quick run the idle goes up to 1.2k at full stop. it just stays at 1.2 it doesnt go up or down,but when i restart the car it idles normaly. strange...
Old Dec 14, 2005 | 04:02 PM
Muckman's Avatar
Moderator in Chief
Default Re: weird idle stuff (nekoabandoned)
vacuum leak.
Old Dec 14, 2005 | 04:03 PM
platinum00's Avatar
small vacuum leak.
hoses heat up after run. air leaks....
platinum.
Old Dec 14, 2005 | 06:56 PM
Default Re: weird idle stuff (platinum00)
ill check the lines
Old Dec 14, 2005 | 08:22 PM
fastrunner's Avatar
Ok I have the same problem but my idle does go back down, after a moment, nothing really weird cuz it doesnt fluctuate it just stops at 1200 then slowly creeps down another 200-300 rpms. The strange thing is that it always idles higher when I have less(close to none) fuel in the tank, I just assumed that was because of air in the fuel line and the fact I have 990 injectors.
Old Dec 14, 2005 | 08:47 PM
Default Re: weird idle stuff (fastrunner)
boost gauge line had a kink,turned into a leak. but i think its the map sensor being stupid
Topdawgg
Sep 2, 2013 05:03 AM
durfeec
Jun 30, 2008 12:03 PM
UNKNOWN_MEMBER
Aug 11, 2005 08:55 PM
mrx
Jun 25, 2005 08:01 AM
1badda
18
Jul 1, 2004 08:02 PM
