weird hp at 10psi
Old Jul 6, 2007 | 01:52 AM
ahmongboi's Avatar
Default weird hp at 10psi
sorry it may have been posted but i don't know. but at 10psi on my 98 b18b i only made 229hp and 209tq isn't that kinda weird. here's the mod.
98 b18b
drag manifold
tial 38mm
t3/t4 turbonetics
rc 440
tune on crome
10psi stock cat and stock pipe stock exhaust.
stock clutch to.
will anything happen to my motor later on if keep running stock cat and pipe.
Old Jul 6, 2007 | 03:18 AM
BDogggUT34's Avatar
Default Re: weird hp at 10psi (ahmongboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahmongboi &raquo;</TD></TR><TR><TD CLASS="quote">
will anything happen to my motor later on if keep running stock cat and pipe.</TD></TR></TABLE>
That's where the power loss is right there. Go to a 3" exhaust and you'll see huge gains with a retune. I made 253whp/222wtq at only 8 psi on a very similar setup but i have a full 3" Kteller exhaust, 3" magnaflow muffler and no cat.
Old Jul 6, 2007 | 06:32 AM
ragethemachine86's Avatar
Default Re: weird hp at 10psi (BDogggUT34)
He's right, it is extremely difficult to make power on stock exhaust piping.
Old Jul 6, 2007 | 06:33 AM
Supacharge's Avatar
Default Re: weird hp at 10psi (ragethemachine86)
get rid of the catalytic converter
Old Jul 6, 2007 | 07:36 AM
street dream gsr's Avatar
* B A N N E D *
Default Re: weird hp at 10psi (Supacharge)
3" turbo back. nuff said.
stock clutch wont be lasting very long. a few power shifts and it'll start slipping everywhere.
Old Jul 6, 2007 | 07:48 AM
thepariah25's Avatar
stock exhaust is no good even when i was NA making 190/137, let alone forcing the induction! If you have to buy an exhaust you might as well step up to the 3" exhaust, but im running my old thermal 2 1/4" exhaust(no cat) and make fine numbers.
my torque even seems a lil high for only making 285whp, i dont always see torque around 225 in that whp range.....but every setup is different, and that was with a cracked manifold on the dyno, so who knows.........
the bottom line, go with at least a 2 1/4"-3" inch exhaust(if you plan on making even more power go with 3" with no cat)
Old Jul 6, 2007 | 07:49 AM
preludestud11's Avatar
Default Re: weird hp at 10psi (street dream gsr)
is your turbo a b or e compressor housing, my friends h22 with the b housing only made like 249 hp at 10psi, very conservative tune. so your numbers sound about right if its a b housing.
Old Jul 6, 2007 | 03:31 PM
PiMpIn's Avatar
Default Re: weird hp at 10psi (preludestud11)
run a 3" kteller and run it to a magnaflow muffler you will see great increases.
Old Jul 6, 2007 | 07:18 PM
Turbo-LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Supacharge &raquo;</TD></TR><TR><TD CLASS="quote">get rid of the catalytic converter</TD></TR></TABLE>
3" cat works wonders
Old Jul 6, 2007 | 10:17 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
either a new exhaust or a Ecut-out, but thats a whole nother problem itself.
Old Jul 6, 2007 | 11:19 PM
ahmongboi's Avatar
alright thanks everyone i think imma go with a 2.5 or 3' piping and magnaflow exhaust and do a retune see where my numbers at. thanks alot
Old Jul 7, 2007 | 09:17 AM
EARLdaSQUIRREL's Avatar
official honda whore
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahmongboi &raquo;</TD></TR><TR><TD CLASS="quote">alright thanks everyone i think imma go with a 2.5 or 3' piping and magnaflow exhaust and do a retune see where my numbers at. thanks alot</TD></TR></TABLE>
before you even think about making any more power, you will need to upgrade your clutch
Old Jul 7, 2007 | 12:24 PM
PiMpIn's Avatar
Default Re: weird hp at 10psi (coptzer)
you will see great increases in power with a 3" and a magnaflow exhaust let us know what ya make.
Old Jul 7, 2007 | 05:03 PM
spoolin turbo s's Avatar
Default Re: weird hp at 10psi (PiMpIn)
3 inch
12 psi:
Old Jul 9, 2007 | 03:05 AM
ahmongboi's Avatar
sorri for the noob ? but what stage or what type of clutch should i get. because i wanted to hold up to about 250-300 hp and i also wanted for daily driven so if i go with the stag4 it will be too hard. what do you guys recommend. type of disc and plate.
Old Jul 9, 2007 | 06:26 AM
my ACT 6-puck solid hub clutch works great to hold my power, but its a lil rough on the leg......not that bad, but im daily driven as well
might want to go with clutchmasters stage 4....it still has a sprung hub
Old Jul 9, 2007 | 07:27 AM
act hdss
Azn Kenny
Nov 13, 2005 02:09 PM
playboyace35
Aug 24, 2005 11:14 AM
18
Apr 21, 2005 11:58 PM
integ6657
Nov 6, 2004 05:48 AM
kidteck
Nov 30, 2003 09:24 AM
