coolant mixture?
Old Jul 17, 2002 | 10:39 AM
05 600RR's Avatar
Default coolant mixture?
I have a Fluidyne radiator and when I put it in I went 50/50 with 1 bottle of water wetter. On my temp. guage I noticed that the car runs hotter than with the factory rad. in it. With it being summer time now and all should I change my mixture to help it run cooler? Any suggestions would be app.
Thanks...Darren
Old Jul 17, 2002 | 10:42 AM
BlueR's Avatar
Default Re: coolant mixture? (itr 01-0492)
more water, less coolant...
if you plan on doing this again when it gets cold , then run just water and water wetter during the summer
Old Jul 17, 2002 | 10:44 AM
Big Phat R's Avatar
Since you live in Nevada - I think you should expect it to run a little hotter in the summer time. What is it about 150 degrees there now?
You are probably also using the A/C alot or continuously and this is going to stress the motor a little more. As long as the car is not overheating I wouldn't worry about anything.
Old Jul 17, 2002 | 10:50 AM
tegtyper's Avatar
Default Re: coolant mixture? (BlueR)
I wouldnt run straight water for extended periods.
along with a lower freezing point, the glycol also provides a higher boiling point, and some anti corrosion properties
Old Jul 17, 2002 | 11:27 AM
05 600RR's Avatar
Default Re: coolant mixture? (Phat Bastard)
No only 105 last week. I never use tha a/c and I don't drive the car much. Mainly just autocross and sometimes to work.
Old Jul 17, 2002 | 11:31 AM
gsr98vtec's Avatar
more distilled water than coolant. its summer you can keep coolant down to about 15% of the mixture.
Old Jul 17, 2002 | 11:36 AM
EagleR's Avatar
Default Re: coolant mixture? (gsr98vtec)
BTW: water wetter will not make any diff with that much coolant in there.....I'm pretty sure it states that on the bottle....
Old Jul 17, 2002 | 11:56 AM
05 600RR's Avatar
Default Re: coolant mixture? (EagleR)
When I put the radiator in it was getting close to winter so I just put one bottle in with plans to change in the summer. Now I am finally getting around to changing out.
raider1qaz
23
Feb 13, 2013 12:18 PM
Obama
Jun 20, 2007 07:10 PM
Osokwik
Feb 22, 2004 08:45 AM
toohott4handlin
21
Feb 8, 2004 03:47 AM
siisgood00
21
Oct 18, 2001 01:14 PM
