Wastgate spring pressures
Old Oct 29, 2005 | 12:33 PM
Tooned's Avatar
Default Wastgate spring pressures
Just got my Tial 44mm wastegate with a 1.1 bar (15.95psi) spring in it and fabbed it onto my manifold. I still can't get boost to hold and was wondering since the 1.1 bar is a dual spring setup if i can remove one of the springs and see if it works.
Also does anyone know what pressure the 2 springs are in the wastegate?
Thanks
Old Oct 29, 2005 | 12:47 PM
NJIN BUILDR's Avatar
Default Re: Wastgate spring pressures (Tooned)
Why would boost hold better with less spring pressure?You can try one spring if you want to have the gate open sooner.Not really sure what your trying to do.
Glenn
Old Oct 29, 2005 | 12:58 PM
Tooned's Avatar
Just thought maybe by putting a softer spring in there and opeing the wastegate sooner to slow down the turbo it wil hold the boost.
I'm cutting the boost right now at 18psi with the AEM EMS. I went from the 35mm deltagate to the Tial 44mm. And the boost is still spiking like crazy.
Garage 808 Hatch
Dec 4, 2006 08:22 PM
eg:R
Mar 6, 2006 01:15 PM
bnut510
Jul 7, 2005 03:41 PM
_Cyclone_
May 4, 2005 02:32 PM
gdrum
Feb 24, 2004 01:55 PM
